993 Forum 1995-1998
993 Trip Computer Dim
Old Oct 29, 2023 | 07:58 PM
MD993's Avatar
MD993
Default 993 Trip Computer Dim
So, I just got my car back from my mechanic who was replacing the fan/alternator bearing due to metallic noise from a failed bearing..
I gave him the instructions on how to remove the fan/alternator assembly and explained to him to disconnect the battery while working on the alternator..
My fan bearing was replaced and my car ran great... until I noticed that the 993 trip computer was very dim..
Something probably went wrong when he disconnected/reconnected battery... or he used battery booster or something maybe..
The trip computer works, but is very dim during day time... At night when I turn on the lights, the rev meter is nicely lit, but the 993 trip computer is still very dim..
Of course I did my research and came to the conclusion that a) the 0,9W blue bulb: Porsche part # 964 641 920 00 is burnt , or b) the N-Channel FET transistor: BS170 needs to be replaced...
After research I will certainly remove steering wheel and airbag to make space to remove the Rev counter...
Before I proceed with ordering parts, which do you think has failed the blue bulb or the transistor..
The 993 trip computer works, no flickering, just dim day and night...
Thanks !!
Old Oct 29, 2023 | 10:00 PM
Foxman's Avatar
Foxman
Good thread Here
As Tore notes, with a bit of patience you shouldn’t have to remove the steering wheel. The part numbers for the bulb and transistor are also noted. Good time to replace both.
Good luck!
Old Oct 29, 2023 | 11:19 PM
Chuck W.'s Avatar
Chuck W.
I had the same issue and replaced the bulb with a B8.4d-W LED bulb from SuperBright. Very easy DIY. No need to remove the steering wheel.
Here is a post from Tore.
https://www.bergvillfx.com/categorie...obc-tachometer
7 Porsche Models That Have Aged Like Fine Wine
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
