993 Forum 1995-1998
Lojack
Old May 28, 2004 | 10:24 AM
tom97c4s's Avatar
tom97c4s
Default Re: Your call to Lo Jack
Originally posted by Martin S.
Let us know what Lo Jack has to say, please!
I called Lojack this morning & the CSR said with little confidence that when your car battery is replaced you do not need service.
I read the manuel and it states "an inspection is required,..if you experience battery or electrical system problems with your vehicle". I told this to the CSR and he still said it is not needed.
So who knows for sure?
They want $69 + parts for a service.
Old May 28, 2004 | 11:00 AM
tom97c4s's Avatar
tom97c4s
I called back to Lojack again and spoke to a more experienced CSR and she confirmed that service is not need for a car battery dyeing or replaced, but if you have some major electrical problems it may be a good idea to have it checked. She also explained that two year service is not needed as well. She suggested to have a service and battery replacement every 4-5 years $110.
Old May 28, 2004 | 11:36 AM
ceboyd's Avatar
ceboyd
yes, I was told that under normal every day driving, the lojack battery should last about 4 years (maybe 5 years)
..BUT, if you remove your car battery in winter for storage, the lojack battery drains prematurely and needs to be replaced.
I also didn't like the NON coverage areas (there were a ton of them)
...and I didn't like that 'fine print' of covering only your deductable... big savings there.
At this point I'm more on the side of the fense of if it does get stolen, I probably won't want it back anyway....
