Stiffness in Shifting
When I got back on the road, I noticed that getting into and out of 2,4,6 (a pulling motion) is very stiff/sticky. Requires an unusual amount of force. 1,3,5 all shift beautifully.
I’ve been researching countless threads and am thinking of a few culprits of what may have happened here. The thread below seems like an extreme circumstance I’d like to avoid (dropping the gearbox and rehearing)
https://rennlist.com/forums/993-foru...-6-help-5.html
I did a transmission flush the next day and test drove it. Definitely a worthwhile job as it helped a bit and needed to be done.
I got under the car this evening and tried to isolate the stiffness by disconnecting the rear rod. I captured a video that shows difficulty with the shift rod connection point. Verified the gearbox seal looks good with the usual slight bit of oil weeping.
I also used the downtime as an excuse to deep clean the shuttle, shift tube, and lubricate the bushings. I noticed a lot old grit at the lower rubber boot from various disintegrated materials as things age out.
Shifting is also hard with the motor off (captured the same in the video).
Any tips here? Should I adjust the forward rod? This car has both the short shift kit and golden rod from Fister. They’ve been excellent but I’m curious if they need adjustment over time. I have some upcoming plans to do my motor mounts. They aren't sagging, but I want to replace them just to keep things tight and refreshed.
Rusty input shaft splines? (Hope not!)
First thing to try, as it is only one the rearmost gear changes, is adjusting the forward rod because this controls gear lever travel/stop. The stress of your unintentional stop may have pushed something out of adjustment (e.g. engine moved foward on bushes). If you are in there you may as well replace all the silicone bushings (4), plastic bushes (4) and the two rod bushes.
I had a similar problem, my transmission was pretty noisy and the shifts were everything other than smooth. I also just did a flush with fresh 75W-90SL and now the car drives like new. I would have never thought that filthy transmission lubricant could have such an impact on the quality of the shifts. Alas, learned something new.
I meant to post the Porsche instructions for adjusting the front rod so for future reference of others, here they are:
