Old vs. New Motor Mount Measurements
Interesting. Üro has a very poor reputation in MB circles, and because I have more experience with wrenching on my MB, I refuse to use Üro parts for mission-critical applications. That being said, I have used Üro parts (as inexpensive as they are) for things like hood shocks and have been quite pleased with their longevity.
If you put your manufacturing reputation into a small area and only two marques, that shows some confidence in your products, with the age of the internet leaving nowhere to hide if things go wrong.
Jlaa (05-15-2023)
Glad a couple of yrs ago bought motor mounts ( with 130k miles knew they were due), went with C4 ones. Then one day one of them leaked and I had them ready to install.
FYI, Autohaus AZ has Rein ones for $120/ea , think those are the ones I got.
Harold
99337504909
Harold
URO only supply the C4 mount after-market, not the hydraulic C2 mount. Visually, to all intents and purposes, the URO version is identical to the Porsche one.
Yes the mounts that I took out of my car all had the six part number on them too.
The mounts I replaced them with were the 049-00 and 050-00 handed mounts. I have no idea why some cars can use handed and some use non-handed mounts. I bought my new mounts in 2015 and finally installed them this year in 2023. Pricing seems to have been better back in 2015. 🤔
Anyways see the handed nature of my two new mounts --- the little hook at the end / asymmetry makes them handed.
So the combination of the colored dots, three possibles in all, and the installation hooks, gives us our six part numbers.
I love it when a plan comes together.
Looking at my originals again (as above) it's impossible to install the wrong handed factory mounts (in a C2 at least) - so either you already had non-factory replacements on your car, or you are mistaken!
Like you I failed to notice the hooks on the originals but after pulling them out of the scrap bin they do have them. As I used non-binary C4 mounts it never came up on my checklist. I looked at Prekom before going with the URO but although they list the 993 none of the replacement part numbers match Porsche's:
Like most others they do not make the handed C2 mounts after-market because of their complexity.
I think as we know how many part numbers there are from the factory, and how complicated that makes life for aftermarket sellers, I think we should cut FVD some slack. Are the factory 964 part numbers for the mounts similar?
Clearly some/most of the factory mounts were of a non-complex rubber construction, and Prekom make 65 or 75 Shore versions that fit.
Once I'd seen the quality of the Prekom materials, and the points I made above, I was sold.
....actually, it looks as if they lifted all of the part numbers from Jackal
http://www.jackals-forge.com/lotus/9..._rsmounts.html
To be fair they are listing all the parts, not just the mount, in their kit. The 964.375.043.81 part number is for the RS mount so I assume they have RS stiffness - dodged that bullet.
It's a choice, not a bullet.
What I meant was that FVD have erroneously used the factory number for an RS mount on both of the above options - HOWEVER they clearly state the Shore or stiffness of the rubber is different for each option.
The Shore 65 mount is to match the NVH of a factory 'normal' mount, albeit without the clever liquid centre of the original factory C2 mount.
So the internet suggests.
