Lost power while driving
If you do everything at the same time, you won't know what the issue was.
I'd do the VR as it's obviously failed, measure the output of course, and then do some driving. But do take the solid state DME with you in the car.
However, I have found that just taking-out/replacing the OE DME (I have two of course!) will usually make it magically work again - the physical movement re-establishing the contacts - but would fail again at some future point.
Which is why I bought the solid-state DME - though to be fair I have not yet resoldered my OE DME contacts.
Use care with the insulator on the alternator as they can easily break and are impossible to find.
https://rennlist.com/forums/993-foru...rt-needed.html
True. However, as much as I would like to nail down the exact root cause, I prefer for this problem to go away (permanently) right now. It was quite a bit unnerving when I lost power on the 2-lane twisty mountain road with no shoulders. Luckily it happened right next to a space for cars to turn around. I shuddered at the thought of this happening go up a steeper hill on that road.
Disappointing results after replacing the voltage regular and DME relay: similar result of 17v+ when idling measured at the battery.
What does this now mean? Grounding problems?
Very strange. Dumb question: do you know if your meter is accurate?
Now my battery reading is 13.4v idling, 12.3v when engine off, and 12.2v when engine off but headlights (tail lights converted to LEDs) on. My battery is 2.5 years old. Those numbers seem low but do they indicate my alternator is on its way out?
The factory voltage regulator for the 993 is set to 14.5V at the alternator because of its location from the battery.
@IXLR8 Thanks. That was indeed rudimentary mistakes from me.
The cigarette lighter based voltmeter told me that the voltage is 13.2-13.3v while driving, idling at 2000RPM, or just idling. Verified at the battery terminals as well.
What does this say about my alternator then?
If all electrical connections are good, then your alternator might be the issue. Turn on more high current loads: high beams, rear window defroster, etc. to load the alternator to see what the voltage is doing.
Either a voltage regulator or a bad power diode in the diode pack. Why not rebuild the alternator if the mileage is high?
Thanks. That makes sense. I'll measure at the battery when I get the Bluetooth voltmeter.
I'm definitely open to have the alternator rebuilt locally.
I'd like to know what the voltage is at the battery, then I'd know for sure.
Well lets hope they do a good job because if it is a high mileage unit, turning down the slip rings to smooth them out (which are already quite thin when new) is a bad idea. They should be replaced. Even Bosch was and maybe still is doing that and you'd think it is a Bosch rebuild.
