Tire pressure: Neverending story...
Now that this controversy will go on and on can someone tell me what the correct tire pressure I should use for thr darn spare tire for the road and supposedly designed for the crush zone design? I think majority of owners with performance oriented cars will experiment with tire pressures no matter what car/tire manufacturer recommends but I do think PAG's recommendation is all about liability concerns versus performance. It is a business afterall and I too would be concerned if there is any liability issues. PAG probably researched that 36/44 will keep it safe for majority of owners and if one decides to lower their tire pressures and get into an accident then it's the owner's fault not PAG's. That's business. Regards. Mike
Keeper of the Truth
Originally posted by 993RS:
Only a very small percentage of Rennlisters are not "average" drivers. After all, as I understand it, there are several thousand members and only a small number of really active non-average posters who are not. Correct me if I am wrong. Is Porsche AG's recommendation "misinformation"?
Trying not to step on anybody's toes here...
In the Owner's Manual which I would think is as official as it comes from Porsche, stated on page 5 and 155 that 36psi F&R for 17" and 36psi front, 44psi rear for 18" for proper COLD tire pressures on "Porsche appoved tires" only.
Haiku Grasshoppa
Can I Drove Your Car?
Er... what's your point?
That's Bubba Guru to you
Just trying to point out that everybody knows where Porsche stands on this issue and what tire pressures to run are in our own hands and believes.
maybee dis be helpin uall. it werked fer ol Red.
hep be onda way fer u
affer u be doin dis klas, den u kin lookee at dis tred agin.
Originally posted by JimBob Jumpback:
Hay Bubba,
Hay Bubba,
Keeper of the Truth
Haiku Grasshoppa
Agreed. If what you mean is that it is pointless for us all to wait with baited breath for RS993 (Phil) to return from the mountain with words of wisdom from his secret contacts at Porsche, then yes, I agree.
Come on guys. I do not have any "secret" contacts, I am going through official channels, phoning Porsche in Stuttgart and Weissach. The only advantage I have is that I speak fluent German, which is helpful. I was told to phone back early next week. I see already though, that no matter what they tell me, this board will not believe it. The board obviously does not consider Porsche AG as a competent and reliable source.
I am sure that safety considerations are a prime factor in Porsche AG's recommendations.
Even if certain performance characteristics improve with lower tire pressure, how can you be sure that a safety risk does not insue? Do you guys have labs to do the testing?
http://www.cbsnews.com/stories/2001/...in308749.shtml
Lifetime Rennlist Member
Posting that story about underinflated tires shows you really have no clue what you are talking about here. The problem that article addresses is running tires so underinflated that a) They build excessive heat due to squirm and b) not enough pressure to support the weight of the tire under moderate/hard cornering. The suggestions being made here are track proven - exactly the venue where temperatures get the highest (where squirm would be fatal) and where handling is pushed to the limits.
This is not about whether Porsche engineering is competent. It is about you spewing BS from mechanics, etc - ignoring the fact that factory recommended pressures are a compromise of many factors. It is about you back-pedaling and changing the topic from the wrong information you continue to try to spread here to something else.
Phil, I know your intentions are good, but the fact is that about half of all the technical information you post is just dead wrong. There are plenty of other boards where this is the norm, but this board has been built over a period of years and provides good solid technical information. We have a long history as a community that will not allow technical BS to go unchallenged and that is why you are contantly challenged here.
Mark,
I do not know how you came to the conclusion that I do not know that the recommended tire pressure is a compromise on a number of factors. I was also under the impression that this is a discussion board. I am therefore confused at your aggressive tone. If this is a board in which only a small number of old hard-core posters should answer questions, I suggest that the rules be changed accordingly.
As to the Firestone story, I just noticed that the tire pressures sometimes recommended here are really way below what Porsche AG recommends. 34/36
Mark,
Mark,
If you want to continue debating this topic, I will be happy to do so on the OT forum. We are getting too far away from the intent of this board, IMO.
Keeper of the Truth
Phil,
I think you are missing a few points here. Let me see if I can clarify them for you. Sorry, I can't do it in German. Hopefully, my broken English is adequate for your understanding.
1- You started this thread by posting misinformation. Granted, that information was given to you by your genius mechanic who you have come to trust after years of experience and you probably had no way of telling if it is accurate or not.
2- Some of us attempted to correct that information. I tried to use common sense while others were basing their comments on pure driving experience. The reason why we did this is because there are many people on this board who happen to drive their Porsche's on the track and are interested in accurate information.
3- No, Porsche's tire pressure recommendations are NOT a compromise. They are ridiculous at best because they don't help the car and/or the driver do anything right. Perhaps, Porsche thinks these pressures are best for high-speed Autobahn driving. If so, they should start calling their cars grand tourers rather than sports cars. I say this, because 36/44 makes any Porsche handle like crap on a racetrack. This fact cannot be argued by anybody including a Weissach engineer. I dare you to go out and try it yourself if you want to see what a non-average Porsche driver can experience.
Finally, my suggestion to you is to go back and slowly read this thread from the top over a glass of your favorite libation. That ought to help you realize how deep a hole you dug for yourself to sink in. Of course, Dan tried to give you that warning but, as you sometimes do, you ignored it.
Phil, I think the point Viken, Dan, Mark, and others have been trying to make is that many of us have indeed driven our cars at sustained high speeds such as those seen on the Autobahn. Our collective experience is not limited to speeds of 65 mph and less as you suggested in one of your posts.
