Mystery warning light?
I am getting an idiot light at start up that is not in my owner's manual (1995 C4.) It looks like a circle with two arrows pointing to each other inside. It is similar (and near) the brake pad wear sensor indicator, but it's not that one. It comes on at start up and then goes out once I start driving.
TIA,
Jack
TIA,
Jack
That's the Brake Pressure Warning Light (C4 and Turbo)
Just wait a few seconds for it to go out before starting your journey. The brake booster needs time to build pressure.
If it doesn't go out, get it checked out asap!
Graham
Graham
Thanks Graham. It has not done that over the last 6 months and just started lately. Sounds normal, but I'll check fluid level anyway. I did recently replace my brake fluid with RBF 600 and bled the brakes and clutch. May need to bleed again to make sure the system has good integrity.
Cheers,
Jack
Cheers,
Jack
