C4S, M030, PSS-9 and Rear Drop Links
I searched the archieves but didn't find the definitive answer to which rear drop links to use to be able to lower the car further than Bilstien's recommended positioning of the mount. The shop is telling us if they lower the mount any further the sway bar will be approaching vertical. The ideal config would be for the swaybar to be horizontal with the drop link coming off at a 90 degree angle.
Anyone solved this problem? What drop links should we use?
FYI..I didn't have this issue with the RS rear sway I'm using. This is for another car I'm helping set-up.
Thanks!
Thanks!
I went to a local race shop and purchased rod ends (heim joints), put the collars in the center, installed everything once, and adjuted the rod ends to meet the sway bars, after aligned and balanced. Saved myself a couple of hours for sure. The parts cost around $20.00. I cant believe these kits dont come with them.
