993 cup gearbox synchronizer rings
Here's something similar to what you are doing I modified the trans to what you have, except for the really low `1st I think you will be happy
the engine is a 993 RSR spec, rev limit 7500, in a 2900# RS/CS chassis in low drag config,, hp is 301 at the rear wheels at 7200
changing 1st is a really expensive proposition, you have to change the trans main shaft
all the internals should be upgraded to at least /31 spec, /30 would be better, the street cars have plastic bearing shells which certainly need to be replaced, shift forks iare another priority item, none of this is cheap, a routine rebuild on my /30 was close to $7k 5 years ago
do spend the money on an asymmetric lsd a GT or factory motorsport would be the way to go here, 40/60 these thigs are magic compared to the old symmetrics
What do you think about the Quaife ATB differential?
I would also for sure choose a plate differential if the car main use was track , and I already know how they work, but maybe they could be better than the oem 964 optional old LSD ?
I used a quaife ATB on a Lotus exige 380 Cup tuned to 430 bhp and even on track with semi slicks it was working well and I Europe I could buy one for 1200 usd
Ok did not know what was required to replace first gear but was expecting something not that simple and more expensive than just a gear change.
the gear type generally work well but only on acceleration, another plus is that they don't add much to the thermal load
the plate type work well on both acceleration and deceleration the asymmetric more so
having a high lock on decel allows more rear brake bias which raises the efficiency and effectiveness of the brakes
I have a 40/40 plate type w/ a bit higher than usual preload in my '76 hotrod and a Porsche Motorsport 40/60 in my 993, Both cars have 993RS brakes which have way more rear bias than the typical 964, Thes lsds are essential to the most efficient braking so I love the asymmetric plate types
Your use will vary
From my perspective, that second gear synchro is the most important one and worth the money.
