Cabriolet top problems.
I have a 97 993 cabriolet that I've recently had problems with. The top on occasion will make a popping sound as it lowers and the top gets stuck in a partially open position until I manually release it.
It's been worked on over the last two months 6 times by two different mechanics. They've reattached the transmisson for the top, lengthened the cables and adjusted the timing mechanism and still haven't corrected the problem.
Has anyone had a similar problem? Any suggestions?
Thank you.
Thank you.
