For those of you with OBDII readers
Can you get real-time O2 sensor readings? Are any of you using the PDA or laptop versions, if so which ones?
I'm trying to re-map the fuel curves with the Split-Second software for the intercooler on the TPC SC, and I need to read the O2 sensor readings to see if I'm running rich or lean. The Split Second ECU does not tie into the O2 sensor readings.
TIA
TIA
