H&R sway bars and springs
Any one here know or is using H&R sway bars. They are suppose to be new in the market but no one, incl my local dealer can provide me any info. They are adjustable (to be confirm in this) and much cheaper then RS adj. Another question I have is that does H&R spring firmer then Eibach? do they sag at all? I heard Eibach sag quite a bit and thats worry me since my front is already uneven?
Thanks,
Thanks,
when I called to ask about them (H&R USA IN WASHINGTON), they told me they are not released yet and are still TBA... no more info either
I have been caling H&R for quite some time...I get the same run around. With Porsche RS bars at about $1,200 a set, I would like another source.
I have TRG (The Racers Group) bars installed. I cannot see, based on the clearences front and rear, how they can possibly be adjusted from full droop, on the lift. Perhaps I need to put the car up on blocks to adjust them, not an option at the track.
I know that Viper Bob has goos luck with the TRG bars, hmmmm.
