oil leak
oil leak
I've recently started expierienceing an oil leak it appears after I've driven the car. It looks like it starts at the center of the engine tray towards the front of the car. The entire motor was taken apart by the dealer exactly one year ago to fix the secondary air passage issue, so I can't imagine it being a seal or gasket.
Could this result from overfilling the oil by a quart to a 1/2 a quart. I am going to be bringing it in shortly, till then any ideas.
If you overfilled the oil, it would be coming back out the filler neck and dump itself on the exhaust. You'd be smelling the burnt oil. Chances are, you do have a leak somewhere.
Sean993,
You're not going to be able to tell much with the tray on. Remove it, jackup the rear end, crawl under, and take a good look with a good light. If nothing is obvious, or it's not clear what the source of the leak is, you may have to wipe down whatever you can get your hands on, then drive it around for a day or three. It should be apparent by that point if it's anything more than a seep. Hope this helps.
Edward
Edward
