Bosch Number on DME
I am looking for my Bosch Number on the cover of my DME on my Tiptronic.
Apparently it is needed for finding the correct program for a chip.
I found the number 0.261.002.288, but apparently this is incorrect.
I have seen the http://p-car.com/diy/chip/chip.htm guide.
Does anyone else have a photo of the cover on a Tip so I can locate the correct number?
Nope, pretty sure its 0.261.002.288, I will double check tomorrow.
Which number on the sticker am I looking for? there is the top one with a bar code and the bottom one with a bar code.
Check out this web site (www.systemsc.com) on the Parts page for the Bosch
DME part numbers. The '95 993 used the 55 pin DME which is the last DME with a
removal EPROM chip. Later DMEs have flash memories (EEPROM) which are not removal.
"The correct Bosch No. is 0 260 002 288 Porsche No. 993 618 115 02."
These are NOT the Bosch/Porsche part numbers for the DME unit. Check the
Porsche PET, as the 993 618 115 02 is a Tiptronic number and
S/B 993 618 115 00. The 115 denotes the Tiptronic. The 120 will denote DME.
The Bosch 260 is for Tiptronic. The Bosch 261 is for DME units.
My car is a British (European) one. Would this still apply?
It seems I may have been looking at the Tiptronic controller, but it is the sticker on the only silver box i can see without taking the seat off. I guess I will have to take the seat off.
I found it, It was hidden under the very front of the seat under the carpet, it seems extremely easy to remove without taking the seat off. The number is 0.261.203.674.
Thanks for all your help and advice.
