Alignment Recommendation
Would like to have my alignment and wheel balancing on a ’96 C2 checked.
Any recommendations for a non ‘butcher’ in the Pasadena / LA area.
Much appreciated. Thank you.
There simply is no choice in the LA Basin, in my experience....go to Johnson's Alignment in Torrance, CA. Call Steve Alarcon at 310 370 6301.
Im south Orange County, Hergesheimer's Motorsports has a super alignment set up.
If you need tires, want them shaved, mounted and or balanced, go to Caldwell Tire in Pasadena, CA. Ask for Matt. He is as much a perfectionist on Tires Balancing as Steve Alarcon is on alignment and corner balancing.
I have known all of the above for at least 10 years...great craftsmen.
If you want more detailed information, e-mail me.
Martin
Martin
Steve Alarcon is well worth the drive to Torrance. Steve not only does excellent work, he stands behind his work. He's done far more than I ever expected when I had a problem with my H&R coil-overs.
You can set the appointment up so you can wait for the car if you can't leave it. I found a shopping center just a couple of blocks down the street with a Togo's, so one day I had lunch while I waited.
Pat, South Pasadena
Pat, South Pasadena
