Michelin PS2 205-50-17 255-40-17
Anyone know if Michelin PS2 comes in 205-50-17 and 255-40-17 ?
Tirerack said so but when I check with Michelin, they said no.
Very confused here.
Does anyone here actually bought a set for the size mentioned above ?
It is to replace my S02PP on my stock 17"rim and want to maintain same size.
Very confused here.
Rhymes With Polo
Hope this helps
a
b
c
d
e
225/45ZR17 91Y RRBL 89192 7.0 - 8.5 8.9 on 7.5 25.0 10.0 833 1356@51
225/45ZR17 91Y MO RRBL 81556 7.0 - 8.5 8.9 on 7.5 25.0 10.0 833 1356@51 MB
235/40ZR17 90Y RRBL 65519 8.0 - 9.5 9.5 on 8.5 24.4 10.0 852 1323@51
245/40ZR17 91Y RRBL 82268 8.0 - 9.5 9.8 on 8.5 24.7 10.0 841 1356@51
245/40ZR17 91Y MO RRBL 92706 8.0 - 9.5 9.8 on 8.5 24.7 10.0 841 1356@51 MB
225/35ZR18/RF 87Y RRBL 87255 7.5 - 9.0 9.1 on 8.0 24.2 10.0 859 1201@50
225/40ZR18/RF 92Y RRBL 93617 7.5 - 9.0 9.2 on 8.0 25.1 10.0 829 1389@50 AU, DC
235/40ZR18 (91Y) N2 RRBL 95853 8.0 - 9.5 9.5 on 8.5 25.4 9.5 819 1356@51 P
235/40ZR18/RF 95Y RRBL 79659 8.0 - 9.5 9.5 on 8.5 25.4 10.0 819 1521@50 MAS
245/40ZR18 (93Y) RRBL 78337 8.0 - 9.5 9.8 on 8.5 25.7 10.0 809 1433@51
245/40ZR18 93Y RRBL 76261 8.0 - 9.5 9.8 on 8.5 25.7 10.0 809 1433@51
255/35ZR18/RF 94Y RRBL 45327 8.5 - 10.0 9.7 on 8.5 25.2 10.0 827 1477@50
265/35ZR18/XL 97Y RRBL 74289 9.0 - 10.5 10.7 on 9.5 25.3 10.0 822 1609@50 MAS
265/35ZR18/XL 97Y MO RRBL 45290 9.0 - 10.5 10.7 on 9.5 25.3 10.0 822 1609@50 MB
275/35ZR18 95Y RRBL 85356 9.0 - 11.0 10.9 on 9.5 25.6 10.0 814 1521@51
295/30ZR18/XL (98Y) N2 RRBL 49127 10.0 - 11.0 11.9 on 10.5 25.0 10.0 832 1653@50 P
295/35ZR18 (99Y) RRBL 43008 10.0 - 11.5 11.9 on 10.5 26.1 9.5 797 1709@51
315/30ZR18 (98Y) N2 RRBL 96031 10.5 - 11.5 12.6 on 11.0 25.5 10.0 817 1653@51 P
225/35ZR19/RF (88Y) RRBL 93379 7.5 - 9.0 9.1 on 8.0 25.2 10.0 824 1235@50
225/40ZR19/XL (93Y) RRBL 93395 7.5 - 9.0 9.1 on 8.0 26.1 9.5 797 1433@50
235/35ZR19/RF (91Y) RRBL 88492 8.0 - 9.5 9.5 on 8.5 25.5 10.0 817 1356@50
245/35ZR19/RF (93Y) RRBL 78831 8.0 - 9.5 9.8 on 8.5 25.8 10.0 807 1433@50
245/40ZR19/RF (98Y) RRBL 68396 8.0 - 9.5 9.8 on 8.5 26.7 9.5 778 1653@50
255/35ZR19/RF (96Y) RRBL 74098 8.5 - 10.0 10.2 on 9.0 26.0 9.5 799 1565@50 DC
265/30ZR19/RF (93Y) RRBL 50536 9.0 - 10.0 10.7 on 9.5 25.3 10.0 822 1433@50
265/35ZR19 (94Y) N0 RRBL 69837 9.0 - 10.5 10.7 on 9.5 26.3 10.0 790 1477@51 P
275/30ZR19/RF (96Y) RRBL 81049 9.0 - 10.0 10.9 on 9.5 25.6 10.0 814 1565@50
275/35ZR19/XL (100Y) RRBL 48468 9.0 - 11.0 10.9 on 9.5 26.6 10.0 783 1764@50
285/30ZR19/XL (98Y) RRBL 41439 9.5 - 10.5 11.4 on 10.0 25.8 10.0 807 1653@50
295/30ZR19/XL (100Y) RRBL 89005 10.0 - 11.0 11.9 on 10.5 26.0 10.0 799 1764@50
315/25ZR19/RF (98Y) RRBL 89776 11.0 - 12.0 12.8 on 11.5 25.2 9.5 824 1653@50
245/35ZR20/RF (95Y) RRBL 52728 8.0 - 9.5 9.8 on 8.5 26.8 10.0 777 1521@50
255/30ZR20/RF (92Y) RRBL 93488 8.5 - 9.5 10.2 on 9.0 26.1 10.0 798 1389@50
255/35ZR20/RF (97Y) RRBL 51832 8.5 - 10.0 10.2 on 9.0 27.1 10.0 767 1609@50 BM
285/30ZR20/RF (99Y) RRBL 59857 9.5 - 10.5 11.0 on 10.0 26.9 10.0 774 1709@50 BM
295/25ZR20/XL (95Y) RRBL 52046 10.0 - 11.0 11.9 on 10.5 25.8 10.0 805 1521@50
335/30ZR20 (104Y) N0 RRBL 81438 11.5 - 12.5 13.5 on 12.0 28.0 9.5 744 1984@51 P
245/35ZR21/RF (96Y) RRBL 74422 8.0 - 9.5 9.8 on 8.5 27.8 10.0 749 1565@50
285/30ZR21/XL (100Y) RRBL 87692 9.5 - 10.5 11.4 on 10.0 27.8 10.0 749 1764@50
295/25ZR22/RF (97Y) RRBL 83945 10.0 - 11.0 11.9 on 10.5 27.8 10.0 747 1609@50
Service Description Key: MO = Mercedes, N0 or N2 = Porsche
Original Equipment Key: AU = Audi, BM = BMW, DC = DaimlerChrysler, MAS = Maserati, MB = Mercedes-Benz, P = Porsche
RF = European designation for XL (Extra Load)
Michelin tires and tubes are subject to a continuous development program. Michelin North America, Inc. reserves the right to change product specifications at any time without
notice or obligation.
1. The dimensions shown are average values for tires measured on specified measuring rim width. Individual tires may vary from data shown.
2. Section width varies approximately 0.2" (5mm) for every 0.5" change in rim width.
WARNING: Serious or fatal injury may result from: Tire failure due to underinflation/overloading — follow owner's manual or Tire Information Placard in vehicle. Explosion of
tire/rim assembly due to improper mounting. Never inflate beyond 40 psi to seat beads. Only specially trained persons should mount tires. Mixing Bias tires with radials on the
same vehicle. Mixing different tire sizes. Follow manufacturer's recommendations.
For high-speed driving, additional inflation pressure and possibly reduced tire loading and/or upsizing is required. In the absence of specific recommendations by the vehicle
manufacturer, use the following guidelines based on those in the European Tyre and Rim Technical Organization Standards Manual. For speeds over 100 mph, load and inflation
must be adjusted according to the table below.
Y-Speed Rated Sizes:
Maximum Speed (mph) 118 124 130 136 143 149 155 161 168 174 180 186
Inflation Increase (psi) 0 0 0 0 1.5 3 4.5 6 7.5 7.5 7.5 7.5
Load Capacity (% of max.) 100 100 100 100 100 100 100 100 100 95 90 85
(Y)-Speed Rated Sizes:
Maximum Speed (mph) 118 124 130 136 143 149 155 161 168 174 180 186+
Inflation Increase (psi) 0 0 0 0 1.5 3 4. 5 6 7.5 7.5 7.5 7.5
Inflation pressure increase must not exceed the maximum pressure branded on the tire sidewall. When a customer requests a replacement tire with a lower speed rating than the
original equipment tire, you must clearly communicate to him or her that the handling of the vehicle may be different, and that its maximum speed capability is limited to that of
the lowest speed rated tire on the vehicle. Exceeding the lawful speed limit is neither recommended nor endorsed.
NOTE: All comparisons are between Michelin tires within this category.
Precision handling and control in
high-speed cornering thanks to the
Formula One-inspired four-groove
tread design, which provides greater
stability in the tread and contact area
under extreme conditions.
Reduced tread noise due to an
acoustically tuned asymmetrical
tread pattern.
Maximum dry grip and handling
without sacrificing treadlife as a result
of a rigid tread design and a softer
and stickier tread compound.
Superior handling and grip in both
wet and dry conditions as a result
of an asymmetrical tread design
featuring more grooves for water
evacuation on the inside shoulder and
massive tread blocks for maximum
handling on the outside shoulder.
Uniform shape at high speeds,
improved ride quality, steering precision
and high-speed durability due to
size-optimized, precisely placed individual
Aramid/nylon hybrid filaments via
patented C3M Technology™.
Extreme predictability in wet and
dry maximum handling conditions
through the use of highly specialized
dual side-by-side tread compounding,
one optimized for maximum dry grip
and the other optimized for wet
handling, wear and durability.
Maximized contact patch area puts
more rubber on the road for precise
steering and confident handling
during extreme cornering due to a
design breakthrough called the
Variable Contact Patch system.
Aggressive styling thanks to ULP (Ultra
Low Profile) technology consisting of a
carcass shape optimized for very short
sidewalls (as low as 25 series).
c
a
e
d
b
Pilot® Sport PS2™
Treadwear 220
Traction AA
Temperature A
UTQG Rating
Max Load
(lbs@psi)
Revs/Mile
at 45 mph
Tread
Depth
(in/32nds)
Overall
Diameter
Width on
Measuring
Rim Width
Rim Width
Range
(inches) Tire Size
Service
Description Sidewall MSPN
MDL42653
2004
Original
Equipment
f g
h
f
g
h
a
b
c
d
e
tread pattern.
c
a
e
d
b
Pilot® Sport PS2™
Treadwear 220
Traction AA
Temperature A
UTQG Rating
Max Load
(lbs@psi)
Revs/Mile
at 45 mph
Tread
Depth
(in/32nds)
Overall
Diameter
Width on
Measuring
Rim Width
Rim Width
Range
(inches) Tire Size
Service
MDL42653
2004
Original
Equipment
f g
h
f
g
h
