Removing wooden shiftknob?
Vic
95 C2
There is a set screw (allen head) under and to the rear of the shift ****. In order to take the **** off, you have to remove the shift boot. In order to do that, I found that I had to unscrew the console. Not a hard job, about a dozen screws.
Did you find a replacement leather shift pattern? Mine was warned out as well. I put in a Momo wood ****. Vic, if I ever make it to Quincy, you can see and try it (tomorrow?)
I actually don't care for the leather insert, and would rather change it out for a black or aluminum one, was curious if it was just glued in or if it does in fact come out.
Vic
95 C2
As Mike said, do not pry the shift pattern cap off, there is an allen scew that holds the **** on.
But, you do not have to remove the console!
Press the driver's side edge of the leather shift boot down with a wide blade screwdriver with a cloth around the blade to protect the leather. There are two flat spring clips that hold the ring around the leather boot in place. Once you have the boot free of the console, lift it up over the **** to get to the allen screw.
There is a few pictures and instructions found in this DIY: http://p-car.com/diy/handbrake/
max
I'm not sure how the insert can be removed, as I couldn't pry mine out. I do like the fact that the stock wood **** is heavy, as Momo one is lighter than I'd hoped.
