Squeak during left turn
Hi,
When turning left and going slow (for eexample in a parking lot) I hear a sequak from the front right. Any ideas on what it could be?
Tom
1995 993
Tom
1995 993
Addict & Guru
Suggest you try: re-torque wheel lugs, check wheel weights (someone actually reported a squeak from a loose weight) & if not that, swap front wheels (if tires not directional) to rule out wheel/tire related cause. Check brake pad not slightly rubbing.
I had a similar noise - pulled both front wheels, checked everything, found nothing, reassembled & it was gone. Go figure! Hope yours is as easy.
