993 Forum 1995-1998
Rear camber
Old Apr 22, 2004 | 12:48 PM
Nemick42's Avatar
Nemick42
Default Rear camber
HI All,
How is the rear camber adjusted and what amoount of adjustment is avaiable without modification to parts etc?
Old Apr 22, 2004 | 02:24 PM
Timothy Stewart's Avatar
Timothy Stewart
For the rear, see posts under "Tire Wear".
tim
Old Apr 22, 2004 | 03:48 PM
Nemick42's Avatar
Nemick42
Tim,
Old Apr 22, 2004 | 09:47 PM
viperbob's Avatar
viperbob
Former Vendor
You have more than enough negative camber capability in the rear than most people need. In order to use anywhere near what it is capable of, you will need camber plates for the front. I run -2.3F/-2.5R with no trouble using the factory rear capability.
Old Apr 22, 2004 | 09:55 PM
jford's Avatar
jford
My camber settings are -2.1F/-2.6R also without any modifications. I do recall seeing a post stating that the rear camber was limited to about -1.5 or so but obviuosly this is not the case.
Jamie
