993 Forum 1995-1998
Rear subframe / control arm bushings replacement
Old 02-11-2022, 01:59 PM
Matthew So
Matthew So's Avatar
Default Rear subframe / control arm bushings replacement
Hi all,
Did anyone tried replacing the rear subframe / control arm bushings on 993 and if yes, any pointers / instruction available for sharing?
Let me be specific, I found a few threads in the forum, while they are helpful but they are not really instruction / step by step type of documentation, hence I am asking here.
The related threads I checked are:
https://rennlist.com/forums/993-foru...ng-thread.html
https://rennlist.com/forums/993-foru...e-bushing.html
https://rennlist.com/forums/993-forum/1077485-solid-or-rubber-subframe-mounts.html
https://rennlist.com/forums/993-forum/1032491-suspension-shootout-bushings-vs-monoballs.html
Thanks in advance!
Regards,
Matthew
Old 02-11-2022, 03:29 PM
aam993
aam993's Avatar
First http://www.jackals-forge.com/lotus/9...suspension.htm (by @jackal2513 ) and then https://edelweiss.smugmug.com/Cars/P...echnical-Stuff (by @IXLR8 ) are part of true treasure trove of 993 diy articles.
The following 2 users liked this post by aam993:
fnckr (02-12-2022), Matthew So (02-14-2022)
Quick Reply: Rear subframe / control arm bushings replacement
