no rear taillights
I have no rear taillights or 3rd lights on my 96 c4S. All of the fuses are fine, the turn lights all work, and the headlights works well. All the bulbs are fine.
Ideas? What am I missing?
Thank you
Michael
Thank you
Michael
ould it be a loose harness plug under the rear window shelf cover or on the right side of the engine compartment right behind the right marker lamp housing?
Have you had any electrical work done lately or replaced any bulbs or put in LED lamps?
Andy
Andy
There is a plastic connector under the rear parcel shelf that goes to those lights from the wiring harness to the brake pedal, easy check for that connection. I recently had this issue after my rear window was replaced and that was the fix. Otherwise you will have to follow the electrical gremlin from the brake pedal back to the lights.
That may not be your problem, but you can add it to your troubleshooting list if nothing else works.
