Invinca-Shield Mess
Had a local outfit install Invinca-Shield on my front bumper -- it's on but is scratched badly in a couple spots -- looks like theywere trying to get the water or air out and rubbed too hard with the applicator.
Shouldn't this stuff go on so without scratches?
Also, is there anything I can use that might remove some of the scratches?
Thanks.
Thanks.
As you dicovered, it'll scratch if they rub really hard with the applicator. I used the a red squeege type applicator that comes with texpel kits as it is softer and make sure the film is wet when I'm squeeging it. You should be able to reduce them using any of the scratch removing type products such as 3M swirl mark remover or Meguiar's Scratch X. Use microfiber towels so you don't add your own scratches.
How about going back to them and demanding they do that piece again or give you a discount.
Mark and Louis -- thanks for the replies -- I plan to talk to them today -- I neglected to order the mirror pieces so I want to put them on. We'll work something out. Still glad to have the protection. I bought a mag bra as well. Did not install the hood piece from Invinca-sheild -- very good combination -- Mag-Bra on the lid with Invinca-shield on the bumper and mirrors.
I wrap the squeegee in a soft cloth when I work out the trapped air. If you use just the bare squeegee, use very light pressure to avoid scratching.
Dave
Dave
I got invinceashield installed on mime. The installer did an outstanding job, no imperfections noted. I would ask them to strip the defective piece and reinstall. On another note..has anyone replaced their side panel factory shields with anything other than OEM material? The guy that did my nose said they have side panels that are cut the same size as the orginals but are .08 thickness instead of the oem .12. He claims no complaints from the ones he's done.
That's exactly the thickness of the Invinca-Shield 3M material: 8 mils vs 12 or I think 14 mils of the OEM pieces I removed; I actually measured the thickness with a micrometer.
Even leaving the huge price difference aside, the 8 mils material is perfect and is a simple FYI as well.
Bill,
I had my side panels replaced when I had an off track excursion repaired(don't ask). Both sides had to be done because the factory side panels are a smaller size. If someone says they have the same size side panel for the 993 check to see if it is the original size or the smaller size being offered now. I will try to take pictures of the smaller ones that I have on the car now.
Gentlemen,
My car needs the clear protector replaced on the rear fenders. What is the proper way to remove the OEM stuff prior to using the InvincaShield kit to install the new panels?
Scott
Scott
Scott -- I understand heat is the answer (hair dryer). I've never done it but that's what others have reported. I'd contact invinca-shield.com and talk to them.
Scott,
Jeff's correct. You want to warm up the material. A hot sunny day will do the same but maybe not with your white car.
In order to leave as little of the adhesive as possible on the car, pull the material at a very shallow angle to the surface of the car. It's like you're stretching it off. This way most of the adhesive comes up with the removed film and you don't have to spend an hour cleaning up the residue on the car.
A little 3M adhesive remover will make the clean up alot easier.
One other tip - you may need to buff out the outline of the factory stonegaurd before you install the new one.
Addict & Guru
