California checking ECU software during smog checks
#31
paddlefoot64 (07-31-2021)
#32
Curious if anyone has had issues with this for their pre-2000 cars. To the OP's point, I'm hoping it won't be an issue for our OBD-2 993s. My 97 993 is due. It's got a tune, but all monitors show ready. .....
#34
I'm about to smog my '97 with giac programming. A 993 authority told me the Bosch ecu is too old for the dmv computer to read in that way so nothing to worry about.
#35
Just s****** my 95 with Steve Weiner GIAC chip. All good.
they have a picture so if you taken the SAI pump off they’ll fail you.
with a well running engine you’ll pass with flying colors. These things burn ALL the gasoline in every cylinder. 15% CO2 is all that comes out.
#41
Basic Sponsor
Hopefully, a smog station, e.g. especially a referee, in the future doesn't use an OBDII scanner to do a CEL reset after passing the monitors test, and then re-checks the state of the monitors test.
Loren
Systems Consulting - Automotive Electronics
Specializing in Porsche cars
http://www.systemsc.com/
Loren
#42
#43
Please tell me more about getting the monitors permanently set. I have an OBD2 993 with cylinder heads that don't have SAI ports, so the whole SAI system is deleted from the car. Is there a way to reprogram the ECU so that the SAI system appears to be present and working?
#45
The obvious solution to me is a collector car Political Action Group that donates to politicians who support rational smog testing laws like California Assemblyman Grayson's AB-467 Historic Vehicle Exemption.
A politicians "principles" are directly related to donations received.
