oil pressure sender zero bar at idle
Thanks for the input guys, i have had this issue for 12 years and replaced the sender three times. I always used 15-50 oil until my last oil change (could not find it up here then).
Only put on 1k miles a year will put 15-50 in next time.
I am thinking problem is gauge,. Any way to test that or is there a fix?
Watson (07-21-2021)
thanks for the offer i am pretty sure its the gauge, i will just source out a used one or get mine fixed, i can do that in the winter as i don't drive it then.
I have the Fisters with Fabspeed 200 cel cats on my 993 3.8L build and have no problems with Mobil V-Twin 20w-50 and great Blackstone reports.High zinc is needed for air cooled V-Twin Harleys and 993's. Check
Porsche and Mobil sites to see recommends. Run Mobil 5w-50 in my 997.1 C4S that has same Fisters and Fabspeed 200 cel cats with no problems.
Oil Pressure Sender & switch:
Withdrawn
If you don't trust your gauge send it out for repair...just for piece of mind....but I doubt that is the problem.
Replace your 0-40 with 15-50.
I would not use 0-40 unless the ambient temperature you encounter is mostly below 15 degrees F.
Air cooled engines operate at temperatures which vary more than water cooled engines and the aluminum case has a different coefficient of expansion than the steel crankshaft,
Engineers design for this in setting clearances.
This is why Porsche specs higher viscosity oil for their air cooled engines.
Dick in TN
BSME, PE Tennessee
911 owner since 1972
Dick in TN
BSME, PE Tennessee
notabot (07-26-2021)
