coliovers with long studs for the front
Folks who tried using PSS10 with monoball mounts(RS, Mode) have gone to great lengths to make the setup work due to PSS10 shock stud being shorter than original RS shock, but that ends up being a compromise with various problems.
Quotes from previous threads:
https://rennlist.com/forums/993-foru...l#post10436376 by @Cupcar "What doesn't make sense here is the answer to the question: Why doesn't Bilstein make a strut with a longer top stud for the Carrera RS so all this custom hardware is unnecessary??"
https://rennlist.com/forums/993-foru...l#post16213489 by @samurai_k "Tonight I was test fitting my mode camber plates and rear top mounts (which are clones of the RS ones). They were previously installed on Bilstein motorsport shocks which have very long threaded shafts compared to the PSS10s which have much shorter ones."
from list https://rennlist.com/forums/993-foru...l#post17392437 that @Bill Verburg provided it seems that RS and Cup got to have longer studs because they are built for RS, is that right? What about H&R green/red/cup/perf-street? And what are the part numbers for these H&R coilovers? Searching the web for H&R coiliovers only brings back "street performance" and "RSS" https://www.ecstuning.com/b-h-and-r-...ion-coilovers/
You may need to call them as such a setup may not be in their general catalog because of the very low number of cars that are in the market to buy them. This is not to say that if you made a written or phone request specifying what variation in geometry you need they wouldn't make up a custom batch of struts for you from parts they have in inventory.
Andy
