993 Forum 1995-1998
Numeric Racing Short Shifter
Old 08-23-2021, 05:59 PM
  #151
boomboomthump
boomboomthump's Avatar
Received 1,079 Likes on 563 Posts
Got mine and it came assembled correctly. The "half moon" notch which mates to the shift rod is facing the rear.
Numeric Racing (08-24-2021)
Old 08-24-2021, 12:17 AM
  #152
Foxman
Foxman's Avatar
Originally Posted by gonzilla
Hmmm. That's interesting. And yeah, I just looked at mine and I see what you're saying. I hope that we can just "take it apart and put it back together," but I'm a little concerned about torque values. I'd hate to put too much lateral force on the bearings (I actually feel the same about the adjustable throw setting). And I guess now I have to buy a second set of Torx bits. Oh well, early adopter issues I guess.
Just made the correction this evening. It was an easy five minute fix. The red thread locker was minimal. Three minutes with the heat gun set at 500 degrees, and it loosened right up. I think the install video mentions a 5 mm hex and a 2.5mm hex. They apparently switched to a 2.5 mm torx bit for the final run.
Looking forward to installing this unit. It looks Ronne very well designed.
Easy fix
Old 08-24-2021, 10:15 AM
  #153
Numeric Racing
Basic Sponsor
Numeric Racing's Avatar
Originally Posted by rsabeebe
i need a '2-fer' deal on this shifter. both the 964 and the 993 need this upgrade.
i watched the numeric install video earlier and really liked what they did to simplify everything and the quality looks quite good.
how many have this installed now? initial impressions?
We are just a phone call away! 844-686-7223
www.numericracing.com
sales@numericracing.com
Ph: 844-686-7223
Old 08-25-2021, 03:21 PM
  #154
Kein_Ersatz
Kein_Ersatz's Avatar
Received mine too, it was facing the correct direction. Added to the fall upgrade / maintenance tasks
Look forward to others experices with their installs and feel.
Old 08-25-2021, 04:38 PM
  #155
boomboomthump
Hopefully @cobalt got his installed before his track event tomorrow. Can't wait to hear his feedback.
Old 08-27-2021, 12:52 AM
  #156
Goose 993
Goose 993's Avatar
Going to put this in tomorrow. The shortest setting is the hole at the end, right? It came pre assembled on the 2nd hole from bottom so not sure which is the shortest one
Old 08-27-2021, 01:12 AM
  #157
boomboomthump
Yes, lowest hole is the shortest throw. It raises the lever 1/2" just like the RS shifter and requires less (shorter) throw on the top side of the lever to move the bottom side the same distance.
Old 08-27-2021, 01:36 AM
  #158
Goose 993
Goose 993's Avatar
I was going to literally PM you but I thought it was late and you were loopy on pain killers 😂
Thanks for the info.
Old 08-27-2021, 09:01 AM
  #159
boomboomthump
LOL... I weened off by Wednesday afternoon.
Between my gallbladder surgery last month and now this one with my foot, I've had my fill of surgeries.
Old 08-27-2021, 09:47 AM
  #160
revolve40
revolve40's Avatar
I really like this shifter. My only complaint is it isn't taller (I'm set up for the shortest throw / tallest height). Another inch or so, maybe even two, would be ideal.
911F1 (08-27-2021)
Old 08-27-2021, 12:01 PM
  #161
boomboomthump
The only problem with that is it would make compatibility with stock/tequipment style shift boots an issue. Wouldn't be enough free material without having the leather fully stretched out.
Old 08-27-2021, 12:17 PM
  #162
revolve40
revolve40's Avatar
True true. Tradeoffs in everything!
Old 08-27-2021, 01:07 PM
  #163
Goose 993
Goose 993's Avatar
Maybe try that swine 11 setup?
Old 08-27-2021, 02:18 PM
  #164
911F1
911F1's Avatar
I think an option to adjust the height of the shifter would have been very cool. I have a Function first shift **** on my car and I have it mounted at the highest point on the shift lever possible.
Its still not tall enough. The stock shifter seems low to me. I like being able to remove my shift hand from the steering wheel and have the shifter close by. More adjustments would be a welcome thing.
Maybe Ver 2.0
Old 08-27-2021, 02:41 PM
  #165
Goose 993
Goose 993's Avatar
Maybe Ver 2.0
The shift lever on this Numeric box can easily be replaced with a longer one. it is just a metal bar attached to the bearings via screws. Could just elongate the top section of the lever after the bend and sell a few different lengths.
911F1 (08-27-2021)
Quick Reply: Numeric Racing Short Shifter
