brighter bulbs needed for front turns and parking
i recently put litronics on my 993, and added internal LED's in them for addional parking lights. they look great but make the incadesent turn, parking and marker lights look like a dirty yellow (lenses are good).
i would like to change the bulbs to brighter looking ones, like the LED replacements or halogen
i have been to the import shops looking for bulbs but they didnt have any for our cars
any ideas where to buy such bulbs?
Doc..
I can't stand those little lights next to the fogs. I, too, searched high and low for a brighter/whiter type bulb to no avail. I ended up replacing the pitted fog light lenses...and took the little bulbs out. Fogs only and clear turn indicators.
If you find these bulbs in a brighter context....pass along where to get 'em.
yes the small bulb next to the fog light is not that attractive when/lit.
i think the cars look funny w/the parking lights on and that is one reason why i added another light in the litronic to fill in the front end when parking lights on
also what color do most use in the turn signal/marker light socket when you have clear lens?
clear or amber?
clear or amber?
but.....there are amber bulbs available that have a silver coating. They will not give your new clear lense an orange aura, but will flash amber when called upon. they can be found at your local pep boys-auto zone type places.
some people on the board have done their own silver bulbs by giving the ambers a light coat of silver paint.
yes changing the turn/marker light to the clear, but amber when lit, would fix the problem of the bulb looking faded next to the headlight .
now need a fix for the small light next to the fog light that looks like has a bad ground it is so dim.
Use a water soluble blue marker pen to color the bulb blue. Takes some experimentation to get just the right amount on so that when lit it appears white.
If you use permanant ink, then you may have problems removing it if you slap it on too thick. But to remove you can "paint" over with marker again and while wet wipe it off or use solvent to remove.
The correct bulb is available at any BMW dealer. I think it's the 10W one that you need. Show them the bulb end and they can get it for you. They werent cheap though, cost me like $20 for it
Addict & Guru
Originally posted by max911
i think most states require a amber bulb for the turn signal (or an amber lense)
E.g., CA Vehicle Code 24953 (Turn Signal Lamps)
related to the small fog light bulb, i discovered that the boxster headlight parking light fits it and it is halogen and looks brighter w/installed than the 993 bulb.
i would HIGHLY recommend removing the fog light assemblies and put in the RS ducts. why you might ask... well just did a track event and it kept the oil temp real nice & cool!!! i couldn't believe what a difference it made, between ducts and fog lights. Hands down - the way to go.
If you want see a pic, look at my most recent post titled "Thunderhill pic"
Cheers,
Boris
Cheers,
Boris
Jauder-
Thanks for the tip. I ordered some bulbs from Autohaus AZ and they were like $6-7 each. Big improvement in the front end lighting.... very white instead of yellow.
For those looking for these bulbs, perhaps you can source them elsewhere for less. This is what I got and they work great!
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
now that this thread is back, i will say that since my last encounter w/993 front end lighting i have also discovered a better solution that just changing the bulbs in the fog lights.
not sure what the RS ducts are(mentioned above), but i put the turbo S ducts in place of the factory fogs, and put silver star bulbs in the duct's position lights, and that gives the best overall front look i have ever seen on these cars, both day and night
