993 Forum 1995-1998
HEADLIGHT LENS TAB QUESTION
Old 05-05-2021, 08:11 AM
alsamrob4
alsamrob4's Avatar
Default HEADLIGHT LENS TAB QUESTION
Just got the car out of storage after a suspension refresh, brake job and 90K service. One of my headlight lenses has a divot out of it. So I want to replace them prior to inspection.
When I went to remove the lenses, I notice that two of the tabs on each housing have what look like little screws with a washer holding the tab in. These are at 3 o'clock and 9 o'clock when facing the light. The hole is round. No hex bit will grip. Is the move to just pop them off? Don't want to do something that will sideline the car while I wait for a part.
I searched in vain for an answer. Any guidance is appreciated.
Old 05-05-2021, 09:09 AM
ed devinney
ed devinney's Avatar
Those are actually where the plastic was melted to hold things together - carefully cut/snap and you're good.
Old 05-05-2021, 09:10 AM
alsamrob4
alsamrob4's Avatar
UPDATE: Pelican's Tech section states: "Two of the catches are "sealed" by a melted down plastic area. Gentle prying broke open the seals." That is the plan. Hope this helps someone else, like me, with limited Interweb and mechanical skills.
Old 05-05-2021, 09:12 AM
alsamrob4
alsamrob4's Avatar
Thanks for affirmation Ed. I'm a measure 3x, cut once person, so that gives me comfort
Old 05-05-2021, 11:03 AM
pp000830
pp000830's Avatar
Received 1,458 Likes on 1,028 Posts
The tabs can be very brittle. So slice the melted part off with care. If you crack one of the tabs it will still work.
Andy
Old 05-05-2021, 12:35 PM
alsamrob4
alsamrob4's Avatar
Thanks Andy. Best implement to free the tab? Should I heat up a utility knife? or just elbow grease and patience?
Old 05-06-2021, 12:13 AM
HalfGerman
HalfGerman's Avatar
I don't remember what I exactly did. But I think I sliced with a razor or exacto blade along the red line. Then using a pry tool or putty knife gently tried to lift the tab to the right of the red line
Old 05-06-2021, 09:13 AM
GJSPIN
GJSPIN's Avatar
I used a very small hand saw to break the seal then gently pried them open. By the way, I have nice pair of used lens available (for sale) if anyone is interested.
Old 05-06-2021, 11:03 AM
alsamrob4
alsamrob4's Avatar
Thanks all. Went relatively smoothly with a small screwdriver and Xacto knife. Once I got past the fact that I had to break the melted plastic I was less concerned about disabling the whole housing and went at it. 10 minute job for a guy with 10 thumbs.
pp000830 (05-15-2021)
Old 05-15-2021, 01:51 PM
pp000830
pp000830's Avatar
Hi Rob,
Any number of approaches will work.
Maybe a pencil soldering iron first to melt around the welded plastic and if that doesn't worry a mat knife or a moto tool cutting head.
The key is to work slowly and avoid or minimize cracking the clips.
Andy
Quick Reply: HEADLIGHT LENS TAB QUESTION
