OBD Scan Tools
OBD Scan Tools
guys,
my car is a 94, and so not OBD II.
Any ideas where I can get an OBD I scan tool from ?
How much does the porsche Hammer cost - are we talking $2k and upwards, or what ??
Ideally I would like a universal job so I can use it on other cars as well (VW, Peugeot, etc).
Finally, anyone got any links to sites that give all the OBD codes ?
If I knew the codes, and the interface details, I could probably make something myself...
Any help gratefully received
Passed On
Far as I know, you're stuck with buying the Porsche tool. '96 and up with OBD II can use generic tools.
Want codes? Buy the shop manual; has 54 pages of descriptions of DME troubleshooting w/ fault codes.
Thanks Ray,
I have the shop manuals, and ****-loads of other books (spent 500 GBP on books prior to and just after buying the car !) :/
The tricky bit though is getting the codes out of the DME/ECU, and lined up nicely on a piece of paper so I can compare them
If I could find details of the interface, wiring, and OBD I codes I could probably make some software to do what I want, but I can't find this supposedly public domain info.
Oh well, I guess I'll just keep looking for a cheap second hand one (yeah right !)
John,
Check out www.geocities.com/vaginfo/ for some basic info on the ISO9141 (not ISO9141-2) protocol used in these cars.
-doug
-doug
Originally posted by John W:
<STRONG>Thanks Ray,
Oh well, I guess I'll just keep looking for a cheap second hand one (yeah right !)</STRONG>
<STRONG>Thanks Ray,
John,
check out www.obdii.com. The moderator of the Pre-OBDII forum (Under OBD-II Discussion Forum) should be able to give you more information.
Hi guys,
thanks for the links, I'll follow them up later.
I have already looked at most of the stuff on obdii.com, but there wasn't anything of help for obd-I, or the manufacturer specific details I was after.
The Vaginfo site looks good though. Hopefully I can expand that to work out how and what the porker stores.
A good friend reminded me that one of our skiing buddies works for Motorola. Guess what he does there ?!?
Yep, engine management and diagnostics !
I'm hoping he will be able to feed me some good info.
Whatever I find out I will certainly pass on.
By the way, I did a search for OBD using a piece of software called copernic. If you haven't tried it, its worth a go.
I found a whole load more info and manufacturers of OBD tools. Funny thing is though, not many can deal with VAG or Porsche
Cheers,
John.
Cheers,
John.
