95 993 is leak down and compression test required
Wanted to get opinions from more experienced air cooled owners on if I should push for the test or if what I am being told makes sense.
Has this car been driven recently? These motors will show terrible leakdown numbers if not driven and a garage queen.
Some of the items will not affect your buying decision or influence price but it is always worth going in with your eyes open:
https://993servicerepair.blogspot.co...-purchase.html
Here are my thought on cylinder tests:
https://993servicerepair.blogspot.co...-down-lie.html
Some of the above is just opinion,
Hope it helps,
Andy
1. Are you getting a PPI from a reputable indy who specializes in air-cooled Porsches? If yes, I would trust them.
2. Do you think the seller will give on the price further, or are you going to walk away from the deal if the leakdown test is bad?
I negotiated on a 97 C4S that was leaking oil (chain boxes, base gaskets, etc) after basically sitting for 18 mos (~500 miles in 2 yrs). PO installed a fresh battery, but would not pass emissions. I put a deposit down, then got a PPI from a recommended shop. I did it in this sequence b/c i only needed the PPI to me if it was something so bad i needed to walk.
The mechanic didn't do a leakdown, but he drove it and said it ran strong. Told me to drive it, and check the oil when warm. If I was filling more than a qt every 1000 miles to bring it back in. I found out later the mechanic drove 50 miles
during the PPI....I wired the rest of the money 30 mins later. Drove it every day for a month and voila...all but 1 of the oil leaks stopped, and i think the last one is really just spilled oil when i added some in. Passed emissions without any issues either.Off topic to leakdown..but the three things i would check are HVAC, driver's door check strap, and rust in the windshield corners.
HVAC - if the evap is leaking it is a pain in the butt to replace.
Door check strap - if it is broken, the A-pillar needs to be cut to reweld the strap in.
Windshield - if there is rust, well, it could be expensive to fix.
I recently bought a 95 993 from out of state from a car broker who suggested a local shop. The PPI didn't say a word about two items that needed immediate repairs costing over $1000. Distributor cap and rotors causing misfiring and all drive belts needed to be replaced. WTF? The best advice is know what to look for and have a well documented car so you can see what has been done.
Dont let this list scare you. Some known issues with these cars and areas to check into are:Compression test / leak down test
Check rust around the windshield and rear glass,
Check for worn suspension components,
Check inner tie rod ball joints in the steering rack,
Front lower control arms wear out between 70-100k (can crack—causing shimmy in wheel)
Look for corroded brake calipers and rust on the shield between brake caliper and suspension (that can rust)
Check for corroded bumper supports especially in the rear (move the bumpers around a bit for a quick check),
Check for decaying spark plug wires,
Check for worn engine mounts,
Check door check straps (do they make noise when opening or doors sag).
Engine case through-bolt O-rings leak oil
Dual-ignition distributor internal belt can fail
Drive-belt pulley
Engine wiring harness was recalled, check to see if the recall fix was performed
HVAC module parasitic drain can discharge battery
Clutch
Clutch slave cylinder can make creaking noise
Clutch slave cylinder hose can leak
Gearbox shift-selector seal can leak
DME relay can fail
Steering rack can leak
Steering tie-rod rubber boots can crack
A/C condenser and oil cooler fan resistors can fail
A/C evaporator can leak
Cooling fan hub bearing can fail
Flywheel rear-main-seal can leak
Engine valve covers can leak oil (Compression test)
Was the underbody panel removed?
Check spoiler going up and down (look at gears—-they can break on the part that rotates up and down)
Shifter bushings and fasteners can have issues
Third brake light bulbs can go out
Vacuum distribution port can collapse
Sunroof seals can fade (difficult to replace)
Sunroof cables can have issues. Little plastic part that pulls down wind deflector can break.
Door-stop mounts can break on A-pillars
Rubber steering wheel airbag mount bushings can weaken, causing the horn to blow unexpectedly or when left signal is turned on, or turning left
Cars that sit can develop problems with congealing brake fluid (white wax material)
- Speedometer, odometer, and/or tripmeter gears can break
- Exterior mirror-bolt trim-caps can be missing
- Windscreen wiper-blade rubber-buffer can be missing
- Windscreen and rear window rubber/plastic trim cracks and breaks. Worse, the window trim plastic is molded to the window, and when it breaks, the fix is to replace the window. The rubber trim that goes around circumference has a felt-like surface, which will creak when it wears out
Look for smoke coming from wheel arches (failed cover and oil being burnt on heat exchangers)
Oil temperature gauge
Inside of brake discs scoring
Were suspension bushings replaced?
Electric windows
Seat height adjusters
Exhaust heat shields and silencer welds subject to rust
All ac vents blowing cold and hot air
Bearing in ac controls for ac sensor squealing (little sensor in HVAC control to the left)
Gap between front bumper to hood
Leaky rack and pinion steering gear
Belt between two spark plug distributors can wear
Limited slip can go at 45 unless a motorsport
OP if you're buying if from a long-term owner, the key question will be asking about oil consumption. That will tell you, not an LD, about valve guide health.
Please cite/link examples demonstrating this behavior.
BTW, one might notice that during the pandemic, planes are flying around with no people. While there are many reasons for this (legal, economic, political), one is also scientific. A plane cannot sit in a hangar for too long. It will begin to fail the conditions it was designed for. Seals dry up, fluids leak, and it will no longer be acceptable to fly it. Either it will then need to be pickled (ie prepared for long term storage) or be flown regardless of passenger or cargo. The science behind this and our cars is the same.
Another classic and somewhat extreme engineering example is the SR71 blackbird. It was designed to be flown in specific conditions..one of which was not sitting on the tarmac. Literally, stuff would start to leak while landing..though this was primarily due to air pressure and temps given the extreme conditions it was designed for. Pilots literally had to come up with creative ways to park the plane to avoid losing control on the ground due to fuel leaks.
3/4 edit: Saw this posting of a 30+ yr old sitting 911 with 'good' leakdown according to the poster. Not sure what the numbers are, but some anecdotal evidence that sitting does not always equate to poor leakdown.
http://forums.pelicanparts.com/porsc...ortomatic.html
Last edited by paranoidandroid; Mar 4, 2021 at 07:31 PM. Reason: Leakdown of a 30+ yr old 911
