993 Forum 1995-1998
Oil Temp Question
Old Jun 13, 2001 | 04:30 PM
911-TOUR's Avatar
911-TOUR
Question Oil Temp Question
Can anyone tell me what oil temperature the ticks on the Oil temp gauge corespond to. e.g. :
Lowest Tick ~100F
Next Tick ~130F
etc...
I used to think I knew, from prior 911s, but I'm not sure I'm right on my 993.
Thanks!
sean
Old Jun 13, 2001 | 05:13 PM
Viken's Avatar
Viken
Keeper of the Truth
Post
First notch: 0
Second notch: 50 C - 122 F
Third notch: 120 C - 248 F
Fourth notch: 150 C - 302 F
Old Jun 13, 2001 | 05:21 PM
Greg Fishman's Avatar
Greg Fishman
Post
Viken,
Do you know what the temp would be just as it entered the red zone. Fortunately I have never seen that, I am just curious.
Old Jun 13, 2001 | 05:32 PM
Viken's Avatar
Viken
Keeper of the Truth
Post
Originally posted by Greg Fishman:
<STRONG>Viken,
Thanks</STRONG>
Greg, the fifth notch is the beginning of the red zone.
[ 06-13-2001: Message edited by: Viken Bedrossian ]
Old Jun 13, 2001 | 05:38 PM
Viken's Avatar
Viken
Keeper of the Truth
Post
My sincere apologies. I missed one of the notches in my original post:
First notch: 0
Third notch: 90 C - 194 F
Fourth notch: 120 C - 248 F
Fifth notch: 150 C - 302 F
Old Jun 13, 2001 | 05:44 PM
E. J. - 993 Alumni's Avatar
E. J. - 993 Alumni
Post
Viken, Where is the sensor that sends the info back to this gauge? Is it measuring temp at the oil cooler or in the engine somewhere?
Thanx,
Old Jun 13, 2001 | 06:05 PM
Robin 993DX's Avatar
Robin 993DX
Lifetime Member
Post
EJ,
I am pretty sure the temperature gague in the dash is displaying information from the temperature sensor located right next to the oil pressure sensor sending unit on the right side crank case.
There is also a temperature sensor on the cylinder head, but I don't think that is the reading you are getting on the oil temperature gauge, and also there is a sensor on the oil cooler up front, but again that is not the reading you are looking at.
Old Jun 13, 2001 | 06:06 PM
Viken's Avatar
Viken
Keeper of the Truth
Post
E.J.
Although I don't know the exact location, I doubt that it is at the oil cooler. It should be somewhere on the crankcase. Hopefully, Robin or someone will tell us the exact location.
Old Jun 13, 2001 | 06:08 PM
Viken's Avatar
Viken
Keeper of the Truth
Post
Robin,
I believe, the sensor on the oil cooler would be a microswitch for the fan.
Old Jun 13, 2001 | 06:09 PM
E. J. - 993 Alumni
Post
Thank you gents. Robin, you say that there are two other temp sensors that don't affect the gauge right? Here comes the dumb question: wht are they doing then? Measuring for the DME? That is all I can think of?
E. J.
Old Jun 13, 2001 | 06:12 PM
Viken's Avatar
Viken
Keeper of the Truth
Post
Originally posted by E. J. - 95 Carrera - No. Va.:
<STRONG>Thank you gents. Robin, you say that there are two other temp sensors that don't affect the gauge right? Here comes the dumb question: wht are they doing then? Measuring for the DME? That is all I can think of?
E. J.</STRONG>
The third one is the cylinder head temperature sensor which is important on an engine that is not water cooled. I think it answers to the DME as do several other sensors.
Old Jun 13, 2001 | 06:28 PM
Pete911air's Avatar
Pete911air
Post
Sean,
Cylinder head temp. sensor is for the engine control unit( mixture@ specific temp.). Temp. sensor on oilcooler turns on oilcooler fan via a resistor to give two different speeds.
Third temp. sensor is for your oil temp. gauge, located on right side of engine.
Pete.
Old Jun 13, 2001 | 07:52 PM
Ran's Avatar
Ran
Post
ON a
-- hot and humid day,
-- with ac on high,
-- and in stop and go traffic,
what should one expect in a 993 or a 993TT if the TT is different in this regard.
Will the temperature that shows up in about 5 to 10 minutes of driving (when it climbs a bit to say the 9 o clock position), continue to keep rising? I've never had to encounter more than 10 minutes when all of the above conditions existed but was curious as regards what I should expect as normal.
Also, in such conditions will one ever see it rise to the 10 o clock notch (4th notch or 120 C if I am interpreting Viken's information correctly).
BTW, in speed it seems to be at the third notch (8 o clock position or 8:30 position / 90 C to 95 C maybe or just a tad higher once in a while) regardless of other conditions. Lower range on cooler days I guess.
Thanks.
Old Jun 13, 2001 | 09:06 PM
Viken's Avatar
Viken
Keeper of the Truth
Post
Ran,
The temperature gauge right at 9 o'clock is where mine stays (pretty much) at during hot days in stop and go traffic and with the A/C on.
Old Jun 13, 2001 | 10:00 PM
Jimmy's Avatar
Jimmy
Post
Ran,
Under the conditions you described, mine is between 9 and 10 o'clock. It rises from the normal highway 8 o'clock to stop-and-go A/C on 9 o'clock in less than 5 minutes. It keeps rising until it reaches 10 o'clock and then it stops. The worst I experienced so far was just past the 4th notch.
