Immobilizer Code success update
I have to give credit to Checkered Flag Porsche here in VA Beach for at least getting the Immobilzer code for me. The Service Mgr looked it up on the computer, and even though he wasn't sure at first if it is the right one, he gave it to me. My guess why the code was readily available in their data base is that the PO already requested it once. So tonight I went and followed the confusing procedure from the owner's manual on how to enter the code, just to verify. After several attempts to do the sequence of steps the right way, sure enough the code works. (Now, if they'll just look up some TSBs for me, they'll totally redeem themselves totally)
Good thing about it I was able to introduce a second remote to the car, so now I have a back up. If you're doing this, you have to do both your remotes right after the other in one session, because if you only introduce the new remote and finish the procedure, the system will delete your old remote from it's memory.
Thanks to all of the Rennlisters who helped me with all the info and suggestions.
Congradulations Mike!! That makes two of us in two days receiving the correct codes and programing spare remotes. I got my codes from Brandywine Porsche in Newtown Square, PA west of Philly.
I'll alternate the use of both remotes every 2 months to keep them in condition, I guess.
I am impressed ...you did this yourself ?? I had neither the patience nor the intestinal fortitude to proceed with the task.
I read the manuals' instructions........huh ? I read them again.....huh ?
Drove the car to the dealer......done in 5 minutes...hocus pocus I suppose!!
I don't know if all cars/alarms work like this but this is what I had to do.
The only problem I had was trying to figure out how to lock the door without setting the alarm. Every time I would lock the door the alarm would set. I needed the remote to disable it and if I used the remote I could not get to the point where I could enter the code. The immobilizer light would not flash. What I ended up doing was putting a spare key in the door lock. I then got in the car rolled down the window and locked the doors using the center console. This would lock the doors without setting the alarm. I then reached out the window and did the unlock-lock-unlock maneuver. Once I got to his point, the rest was fairly straight forward.
