Door lock removal suggestions
Hello
I would like to remove the door lock mechanism from the door to make a small tab mod as on the rs to be able to lock and unlock the door manually with the key
Does anyone have any suggestion or pictures on how to remove it from the door?
I removed the door panels and all but the window frame rail is just in front of the lock mechanism and I don t know if it has to be removed or if the lock can be moved sideways and removed
The doos can be locked and unlocked as is, not clear what you are trying to do???
The lock is part of the door pull and the two nuts holding it from the inside of the door can be accessed by just removing the plastic latch rain shroud internal to the door held in place by two small screws in the door jamb facia.
Andy
Andy
Andy
Andy
Then on some cars that are fitted with the central locking there is only one tab ( to unlock the car ) but the locking tab is missing and the key when turning just activate the electronic central lock actuators.
As on my car there is fitted the central locking version with just one tab ( and for some reason the central locking is not working but it s a partially stripped car converted to RS ) I would like to weld the second tab on the existing mechanism
I managed easely to remove the inside panels and different screvs and rods holding the mechanism in place but just in front of it there is the window sliding rail that is part of the window frame and I don t know if the mechanism can be taken out of the car without removing all the window system from the door
If you look at some pictures of spare 911 door lock mechanisms there are some that are made with 2 little tabs that are the parts that get moved by the key lock itself and one tab is for locking and the other for unlocking as for example on the RS models.
Then on some cars that are fitted with the central locking, there is only one tab ( to unlock the car ) but the locking tab is missing and the key when turning just activate the electronic central lock actuators.
As on my car, there is fitted the central locking version with just one tab ( and for some reason the central locking is not working but its a partially stripped car converted to RS ) I would like to weld the second tab on the existing mechanism
I managed to easily to remove the inside panels and different screws and rods holding the mechanism in place but just in front of it there is the window sliding rail that is part of the window frame and I don t know if the mechanism can be taken out of the car without removing all the window system from the door
I seem to recall there was a design change somewhere between the beginning of production and 1996 where a switch in the door was eliminated. I bet looking at the parts catalog will give some insights and may even suggest what parts can be ordered to turn the locking function into a purely mechanical one.
Andy
