Wheel p/n id, please..
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I spent the last 25 minutes reading through the archives, but cant seem to match this 18" twist wheel p/n that I have with anything.. Maybe its a Boxster wheel?
Anyhow what are these wheels?
p/n F: 993.362.134.05
p/n R: 993.362.138.00
I am guessing solid spoke boxtser?
i just found the fronts on the PET for the 996.>> 7.5x18 ET50 with the M408 option. when i punched that code into the kindel option decoder, it said Technology wheels.
YMMV
YMMV
PET doesn't recognize either number for some reason. However, http://www.pelicanparts.com/catalog/...arch_query.htm shows that one is an 18x7 "wheel" and the other is an 18x9 "Turbo wheel". So I assume that teh first one is solid spoke wheel and the second one is hollow.
Max, how did you find these in PET? Mine said "invalid part number".
i just visually checked out the wheel section of a bunch of 993, 996 and boxster model years.
i couldn't find the second # , although there was a wheel with the same number if you substite a 996 prefix
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
BTW, thanks all for the replies!!
Chris, on top on the right, below a yellow flag, there is an icon that look like a sheet of lined yellow paper. It's called Functions. If you click on it, a drop-down list will appear. The first line on the list is "Enter part number".
