Rear spoiler missing parts
I bought a 993 about a year ago. The previous owner replaced the rear spoiler with an RS wing. He included the original spoiler but when trying to replace it again, I found out that it was incomplete.
Below is a list of the missing parts as itemized by my local Porsche dealer:
Now this is a very long and expensive list (sums up to north of $1k). My question is, do I have any alternative options to restoring it to original? Should I look out for complete units being sold by other owners replacing their rear wing? Are there other sources for parts I could source these from? Any recommendation or advice is much appreciated.
- 964-512-050-00 1x Lever (Link) $150
- 993-512-717-00 1x Cover satin black (Link) $148
- 964-512-212-00 1x Connector plate (Link) $117
- 993-512-533-00 1x Back panel lower seal (Link) $73
- 964-512-461-00 1x Connector plate base (Link) $23
- 964-512-722-00 4x Spoiler mount bolt (Link) $16
- 964-512-723-00 1x Spoiler mount bolt (Link) $16
- 964-512-531-01 4x Stopper (Link) $14
- 964-512-721-00 2x Lever mount bolt (Link) $10
- 964-512-467-00 4x Connector base plate (Link) $7
- 900-119-107-07 6x Connector plate bolt (Link) $7
- 964-512-732-00 4x Outer panel bushing (Link) $5
- 999-911-614-40 1x Sealing strap (Link) $3
- 999-088-025-40 8x Vent grille screw (Link) $3
- 999-073-122-09 2x Screw 4.2x9.5 (Link) $3
- 999-703-449-40 6x Protect cap (Link) $2
- 999-703-363-40 4x Side support buffer (Link) $2
- 964-512-711-00 3x Plastic sleeve (Link) $2
- 964-512-741-00 2x Plastic washer (Link) $2
- 964-512-751-00 4x Plastic washer (Link) $1
- 999-025-209-40 16x Rubber washer (Link) $1
- 999-591-723-02 2x Speed nut (Link) $1
- 964-512-742-00 1x Plastic washer (Link) $1
- 999-591-746-03 3x Cable clamp (Link) $1
- 477-971-851 12x Ignition wire clip (Link) $1
- 999-591-974-01 8x Back panel clamp (Link) $0.50
You probably could find a complete unit for less, but then might have to pay more to paint it. Or sell the RS wing to cover the cost of the replacement.
If you go that route, I might be interested in the RS wing.
