993 Forum 1995-1998
And Yet Another Oil Question
Old Sep 17, 2020 | 10:06 PM
Twilightblue28A's Avatar
Twilightblue28A
Default And Yet Another Oil Question
When topping off my oil level, am I ok using 5W-30W Mobil One? To be clear, my question relates to adding oil not an oil change.
Thank you
Old Sep 17, 2020 | 11:08 PM
mike cap's Avatar
mike cap
Assuming you’re using Mobil One in the engine now but just a different weight then you’re totally fine.
I wouldn’t mix brands of oil in my P car.
Old Sep 18, 2020 | 02:39 AM
pp000830's Avatar
pp000830
Hi Harry,
As Mike says,
This is OK as there are 12 quarts of oil in the engine and adding even a quart or two will not significantly alter the effective viscosity properties of the oil fill. I don't even have a concern about it being the same brand as long as it is the same API specification as specified by Porsche for our cars.
Andy
Andy
Old Sep 18, 2020 | 03:01 AM
Twilightblue28A
Thanks a lot!
Old Sep 18, 2020 | 05:12 PM
IainM's Avatar
IainM
ican understand not mixing dino and synthetic but brands?
whats your thinking behind this?
Old Sep 18, 2020 | 10:05 PM
mike cap's Avatar
mike cap
Generic response - brands should be specs like Andy said. His response is more accurate.
I use Motul now in the two P cars and was thinking I wouldn’t top off with Mobil One. But I’d specs are the same I guess I could.
Old Sep 19, 2020 | 02:18 PM
notabot's Avatar
notabot
We’re a Liqui Moly family.
