I think a car bra can do more harm than good. Paint will fade differently under the cover and any movement or abrasion to the paint surface will cause harm (flapping while driving). I’d live with road rash instead. Plus I don’t care for the look. Maybe a black bra on black car is ok but otherwise I wouldn’t bother. And even then, the line across the hood... ugh.
Agree with stevensivak not to waste time as the windscreen alone is more than $500.
I have worries about the stone damage to my 96 Cab's nose, and wondered about getting a bra for protection.
I have seen some threads on this on Rennlist, and several talk about removing the bra often to get rid of moisture, etc.
OTOH, I have heard too much abou the clear wrap, in that it turns yellow and might affect the paint when removing it.
What's the present thinking about protecting from stone damage?
Thanks.
The yellowing with clear bra is not really a thing any longer. Quality is way up in that regards and as long as the paint or repaint was done correctly it shouldn't be a problem to remove. If I get my nose re shot due to chips that are starting to annoy me, I'll do Xpel or the like, but thats me. painting a panel is ~$800 based on my experience with my other cars so it in theory will keep it looking newer longer.
My caveman estimates to avoid wearing a bra. Based on my car actuals the last couple of years by high end shops and perfect results.
- Paint correction and Ceramic Pro including wheels and calipers. Paint was perfect prior just swirl marks = $1500
- Clearplex on ws = $500
- Xpel or similar on headlights, fogs, full nose, side mirrors, inner fender painted arch area and redo factory PP forward of rear wheels. After 18 years of ownership that’s all that needs protection = $1500
A roll of the clear protective film is just a few bucks on eBay. It is really easy to apply with water and a little wetting agent. It is similar to the factory-applied protection to the rear wheel arches but a little thinner.
For me throwing hundreds or thousands of dollars at a process that can cost twelve bucks to do without trying my hand at it first fails the logic test for me. I made the cut-out shapes and replaced the wheel arch protectors myself.
Turns out it was exceedingly simple and easy. Applying a 12" wide band of the protective film across the bottom of the hood to protect from stone chips seems like a DIY no brainer.
I am sometimes shocked at what folks are willing to pay for sealing or putting other easily applied non-paint coatings on their cars, it's just me I guess. Then again I don't own a black car and I do drive my 993 as my primary vehicle, so to each their own I say.
Andy
Andy
Andy,
Damn, you're right!
Sounds like a DIY video someone should make!
After having the bumperette holes filled and then the bumper-cover painted I had a PPF applied to the front of the car up to the windshield and also on the mirrors and headlights. You have to look very carefully to see it and I don't think it cost that much but gives great piece of mind. Each to his or her own!
Andy
true to some degree. the no name brands i'd steer clear of, even 3M that I used for the rockers on my truck is complete crap, its adhesive isn't as good as the Xpel. It was worth the experiment, but did have the compound curves of the truck nose and hood done by a professional and it was totally worth the $'s for a quality job. This type of thing is more art than science, kind of like sheet rock and using mud to smooth the walls, pros have it down and it looks great. the weekend warrior, not so much.
Had a friend who tried applying clear film to his murcielago. Disaster! Looked awful. Spent hours trying to apply like a pro and then hours in the sun hoping the bubbles subside and finally hours removing from the car and hiring a pro.
We’ve had PPF applied to a couple cars in our garage. We create as clean an environment as possible. Watching the pros work I would never attempt it myself. Maybe I’d try the stone guards as they are small areas. But other areas?? Fuggedaboddit!! It truly is an art. Worth the cost for a well vetted pro.
