Engine bogs after revving
3.6L VarioRam. Getting a slight bog/drop in rpms after giving her a little throttle. Happens both when she’s cold and warm. Any input on potential items to look at appreciated.
Thanks,
MJ
Thanks,
MJ
Any CEL? Check Distributor, wires, fuel filter, vacuum leaks etc..... list goes on
pp000830 (09-04-2020)
The idle control valve takes over when you let off the throttle. If you are not getting any CEL etc then you may as well start there. Use Google to search RL (easier) or have a read here: https://www.pelicanparts.com/techart...eplacement.htm
