ISO - CR1 Adapter, Help?
Hello,
With Bergvill FX's old webshop closed and no new website online, does anyone know where else to buy or how to build this thing?
Seems to be pretty niche as it only applies to the early CR1 radios.
https://www.bergvillfx.com/index.php...-928-cr-1.html
Thank you,
Alfa40
Thank you,
Alfa40
I was able to use an ISO 16 pin connector and just swap a lead or two if I recall correctly - I did cut one of the four sides off one of the female plugs so I could slip the factory 10 pin connector into the 8 pin connector. Simple and worked perfectly.
Pretty sure mine was ISO 16 pin to Clarion adapter to just plug into my new head unit.
