993 Forum 1995-1998
distributor problem , HELP
Old Aug 28, 2020 | 07:11 PM
981x's Avatar
981x
3rd Gear
Default distributor problem , HELP
Hello everyone,
i have recently taken the distributor out of the car to replace the distributor belt but now after putting it back the car won't start. ignition is working and the engine is turning, but there is no fire . i made sure when i removed the distributor that the engine was at TDC and the rotors on the distributor ware pointing at the marks on the distributor housing . i did not move or turn the engine by hand when the distributor was out and put it back exactly how it was . any idea how to solve this ?
car is 993 C2S
Old Aug 28, 2020 | 07:40 PM
71-3.0-911's Avatar
71-3.0-911
Are you sure you're on TDC compression stroke? If it was put back exactly as before then it will work. How did you verify spark?
Old Aug 28, 2020 | 07:54 PM
pp000830's Avatar
pp000830
Yes I believe in 4 stroke engines one needs to be in the compression cycle not the exhaust cycle even though they both share the same mark on the drive shaft.
Old Aug 28, 2020 | 08:34 PM
Endoman's Avatar
Endoman
Don't panic back to basics, take it out and check again. This may help :-https://www.porscheclubgb.com/forum/tm.aspx?m=1066137
Old Aug 30, 2020 | 04:42 PM
IainM's Avatar
IainM
rotors both pointing to their respective #1 marks?
Hall effect sensor plugged in?
Did you mess with the cap & wires at all?
Dizzy fully seated in case & bolted down?
not much else to go wrong.
