ok to drive on slightly bent rim as interim...
picked up some new so3's a week or so ago & found out my d-side (18'twists) were slightly bent.
this was detected during balancing them, one of the techs said he'd simply balance them the best they could, but that they were bent. he showed me & i noticed an ever-so-slight waver in the inside edge of both front & rear wheels... probably from a pot-hole.
(was a little bummed as i wanted to use this set for the track as i'll be prepping the car for some 'de' time later this year... but hey, cest'la vie)
i've since ordered new wheels & as i await delivery, i'm driving on the bent ones...
is this in fact, alright to do?- i've also toned down my driving a bit just because i'm a little leary. but do i even need to fret though? as i drove on these for about 10k (car now has 26k) w/o knowing they were tweaked in the first place by the p.o.
also, by any chance does anyone have a set of frt & rears which they would like to sell ouick?
thanks for help w/ my probably 'stupid/lame' question.
A slight wave in the wheel is nothing to worry about. As long as the bead is maintained, and it sounds like it is, you should have no problems. This is especially true if they can still be balanced. I have street and track tires that I have used for years that sound like they are a lot worse than yours, and I've had no problems. In fact, I'm wondering about the advisability of having them straightened. That would result in a round wheel that has been bent twice! The quality and composition of the wheels certainly has something to do with this. My Audi has snow tires on some Ronal wheels that are pretty wavey, but they have been that way for years. I have Kinesis wheels on track tires for my 993 that are slightly wavey, and I check them daily when on the track, but haven't seen any progression or air leak.
Chuck
Chuck
I drove about 400 miles on a bent rim once, not by choice as I was away from home. No problem if there is no crack, I suppose. I had the wheel repaired when I got home.
Addict & Guru
Re: ok to drive on slightly bent rim as interim...
