Crazy quote - speechless
i wanted to hear your thoughts and experienced feedback on today’s experience.
I had an abnormal wear on the inner part of front right tire (toe in)
I go to an Indy shop specializes in European cars here in South GA and ask if I can have an alignment done and with the occasion ask for a quote for installing 10mm spacers in the rear; this was supposed to be done by removing front studs to put in the back and install new ones (in my possession) in the front (5mm spacers).
I can understand a quote for 780$ (labor only) for the installation the spacers and new studs on four wheels; this, although can be avoided, very likely may involve the removal of all hubs in order to do an accurate job.
Another shop, months ago in JAX quoted me 650$ For the same service.
what I cannot understand is 580$ for an alignment.
580$!?!?!?!!
A normal alignment for a regular car at “Uncle Joe” alignment shop in town is around 40-50$.
I paid an alignment 110$ in the past from a good Indy shop in JAX FL
but 580$ sounded completely out of common sense.
these guys not even looked at the car but apparently just looked at an online “hour book” and made the quote.
they asked me to leave the car overnight for an alignment....took this excuse to run away.
the explanation for the high quote was that there are a lot of manual regulations to do, was that they’d do a perfect job.... mine is a fully daily drive street car not even a track day car.
I understand too quality service and needs to be paid but 580$ for an alignment without even looking at the car.... doesn’t sound very professional.
I ask the expert of this is possible or was a galactic joke...
or if, for competition purposes, this is normal.
thanks!
580$!?!?!?!!
thanks!
Not sure about the 993, but with most Porsche models there is adjustment available for toe, caster and camber at the front and toe and camber on the rear. Couple that with the potential to corner balance too there is a whole lot more work involved than the typical "wheel alignment" offered by the local Indie shops.
A full alignment by a knowledgeable technician can take as much as 6 hours using quite expensive equipment. It can be done quite successfully with string and protractor, but, it is time intensive.
580$!?!?!?!!
thanks!
I believe I paid in the $400 range. It's not cheap to be done properly. That said, $580 is alot, but believable. Maybe they were trying to price you out - make it worth their time to do something they weren't familiar with doing?
I'm originally from South Georgia and I'd be surprised if there was someone down there competent to properly align a 993. I could be wrong though. Not sure where you live, but a safe bet would be somewhere in Florida or go up to ATL. I did mine at NolaSport in New Orleans and they did a good job using the proper tools.
Key question - ask them if they have the kinematic toe arm alignment tool. One local "Porsche expert" told me the tool was "too expensive" and he didn't use one. Very easy to ruin the driving experience of these cars with a bad alignment. I know from first hand experience.
It is definitely not a 1 hour job. The price quoted seems fair.
what the hell are they doing all the time?
My guys here need far less than 3 hours on a track setup for a completely messed up (dismantled) turnbuckle setup ...
Wouldn't being fair to mention what you pay for such job here ...
It takes me around 3 hours easy, by myself.
Issue is that you have to finish alignment, and go for a small ride, re-install car and everything, and recheck
if all levels good as you wanted, three hours is logic
at +/- €125 per hour without tax @ porsche , price above is not shocking, and porsche here redo alignment if you test drive car with mechanic and something doesn't suit you
If instead they are going to do it with the standard system, without corner balance, I think here the cost would be, for a 1 hour check and small adjustments 60 to 80 euro and for a total setting, with change of some components (like for example the old tie rods) something between 200 and 250 euro.
The fact is, if you enter with a beautiful girl, dressed in red in a restaurant, aren't all the people going to watch her? So you must pay more, otherwise change to an ugly one and maybe you'll get a discount from the standard price.
well this was exactly my point of the post.
very honestly didn’t know it could take that long to do a good, high level alignment; now I understand better.
you think the studs replacement for 4 wheels is too high?
But that wasn't my main point. It was more, what the hell did someone actually do for $110? Sounds like a 1 hour labor charge, which in reality means they probably spent 30-45min on it?
My other point was really that it seems like you were OK with spending over $500 to replace wheel studs but didn't value a complicated wheel alignment at the same cost. Understand now you did not realize how much adjustability is available on these cars but I guess the way I look at it is: wheel stud replacement (low level grunt work), wheel alignment (specialized tuning of the car). I'd value and pay more for a proper alignment than having someone replace a few bolts.
I think I pay $400 or so for a four wheel balancing by a shop that knows how to adjust kinematic toe.
