993 Forum 1995-1998
Reinstalling headlight - having trouble
Old Jul 11, 2020 | 06:52 PM
mathfuzzy's Avatar
mathfuzzy
Default Reinstalling headlight - having trouble
I installed new lenses on my headlights. I gotta say, that was a very easy and relatively reasonable DIY that dramatically improved the appearance of my headlights. I guess after 20 years, the plastic lenses just yellow. So, all good removing the units and installing the new lenses. The trouble is getting them back in and locked in place. I don’t ever remember having a problem before. When I try to get the right side back in, it goes in fine, although doesn’t quite seat, which seems right, with the locking lever in the up position. Then when I try to lock by rotating the lever forward, I can only get 3/4 of the way down. And the light isn’t noticeably seating when it’s there. If I try to push past 3/4, the locking lever cams out of the light and the light unit comes forward.
Am I doing something / missing something obvious? Or is the unit misaligned? Or something else?
TIA
Old Jul 11, 2020 | 06:55 PM
pp000830's Avatar
pp000830
I find that one needs to Teflon or silicone lube the headlight's pod tracks and rub a little lube around the socket seal for the electrical. This will make it much easier to seat the pod fully.
Andy
Old Jul 11, 2020 | 08:43 PM
JimPA's Avatar
JimPA
I hope you added Xpel (or similar) film to your new lenses. Resists cracks and, especially, sand pitting. It should keep those lenses looking fresh for years.
Old Jul 11, 2020 | 08:54 PM
GJSPIN's Avatar
GJSPIN
I just did this on my 993 C4S. The new seal on the lens is fighting you. You need to push the unit back into the respective fender opening with some extra pressure. Once that's done and they're fully seated all should be well.
Old Jul 11, 2020 | 08:57 PM
993pbug's Avatar
993pbug
^ This! Once the lock is engaged, I just gave the front of the light a thump, and it locked right in. Of course, it took me 20 minutes of fighting the lock before figuring it out as well
Old Jul 11, 2020 | 10:22 PM
HalfGerman's Avatar
HalfGerman
I had the same thing, one side went in fine, the other: 30 mins of .
Old Jul 12, 2020 | 02:05 AM
Churchill's Avatar
Churchill
Use your palm on the glass to fully seat the headlights. The locking arm should not be used to seat them -- it's just to lock them in place once they're seated.
Old Jul 12, 2020 | 11:43 AM
gmorat's Avatar
gmorat
I did this a few years back and inadvertently put the left lends on the right bucket and the right lens on the left bucket. Amazingly the lens will go on either bucket but then won't go back into their holes.......not saying you did this but it is possible.
G
7 Porsche Models That Have Aged Like Fine Wine
Old Jul 13, 2020 | 07:00 PM
mathfuzzy's Avatar
mathfuzzy
G
I never would have thought of this, but I wonder if it's possible. I replace them individually...so didn't pull both units at the same time, but I'm wondering if I inadvertently re-installed the new ones on the wrong side. Seems unlikely, but both sides were a problem and I seriously shoved both in place with my palm before trying to lock. The left side ended up locking, but the right side is stubbornly not locking and it's like I'm forcing it. If someone has a picture of the right side lens markings, both for that matter, it would be helpful.
Old Jul 13, 2020 | 07:04 PM
gmorat's Avatar
gmorat
Sounds familiar. Drove me up the wall cos I had two 993's and was swapping lenses back and forth and just couldn't figure it out.
Old Aug 4, 2020 | 08:14 PM
mathfuzzy's Avatar
mathfuzzy
For posterity - this was the problem. The driver side went back in basically fine...a little struggle, but not that big a deal. The passenger side WOULD NOT lock. I ended up getting it close and securing the locking arm with a zip tie for the last few weeks. I just got replacement bulbs (highly recommend the LED bulbs from Gert) so had to pull the headlight units out. As commented, the new seal was fighting me. Driver side went in a bit more easily this time and I REALLY shoved the passenger side in to seat it and got it to successfully latch / lock.
Old Aug 5, 2020 | 03:03 PM
drodg's Avatar
drodg
I think my right side gave me fits also and with extra pressure it finally went in.
Old Aug 5, 2020 | 03:47 PM
71-3.0-911's Avatar
71-3.0-911
Make sure the pins are aligned on left and right sides with the channels. Then gently slide in and press with your palm firmly in the lower half of the headlight. If done correctly, lever will glide into place easily as you push.
Old Jan 28, 2025 | 10:34 PM
FLPorsche's Avatar
FLPorsche
TIA
God, I thought it was me! I experienced this exact thing today—swapped out the lenses with ZERO difficulty, but reseating them was the task from Hell. Result? FAILURE! I couldn’t get either unit to properly reseat—getting the lever back down (forward position) was impossible, extremely hard, even putting my knee against the headlights for added leverage. Units kept trying to pop out when I moved the lever forward. Felt like I was going to break something. Gave up and reinstalled my old lenses and then put the headlight units back in—went in like butter—a child could put the lever back in place. And yes, genuine Porsche parts for the 993. What the overall @#&!!!!? I’ll try something else tomorrow, cuz it has to work, right? Right?
Old Jan 29, 2025 | 12:21 AM
boomboomthump's Avatar
boomboomthump
This is because the seal around the new lenses hasn't flexed into position yet. The old ones are "trained" and not fighting you.
Use a heat gun on LOW and keep it away from the seal several inches but keep going around it for a few minutes slowly/patiently. Do not over heat them or you will destroy them. They key is warm them up a bit so that when you push, they conform into the opening and you'll easily be able to lock them in place. Don't remove them for a few days at least so they conform to the shape permanently.
Warning, if you ruin the seal, you cannot buy the proper one. Porsche sells replacements but they switched them to some soft foam rubber crap that is a nightmare. They are nothing like the originals. If you buy the lenses, they come with the original style seals. So fair warning to use that heat gun sparingly or you'll be buying new lenses simply for the proper seals.
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
