Best Pedals for Heel Toe functionality | 1997 Porsche 911 993
The brake and accelerator pedals are at different levels/distance to the driver.... and they are pretty far apart. Presently, heel/toe requires taking the foot off of the brake momentarily (unless the driver has Shaquille Oneal feet). The heel/toe bridge is simply not possible.
For the 1997 993, what are the best replacement pedals that would make the heel/toe technique most achievable? |
Wiil do. Many thanks!
W |
you can adjust the brake pedal level a bit (if the connection is same as a 964 and i believe it is as i have a 993 brake setup on my 964) . While I have rennline pedals and the fully adjustable gas pedal on my 964, the only porsche i've ever driven that i can't heel toe (barefoot, in flip flops, or in driving shoes...) is a G series. Their placement is bad. i don't have huge feet.
The extensions can help, the rennline is good. But, usually you want the brake level with the gas when you are into the brake hard, that's when you want to really heel toe. |
Originally Posted by Spyerx
(Post 16766056)
The extensions can help, the rennline is good. But, usually you want the brake level with the gas when you are into the brake hard, that's when you want to really heel toe. Thank you https://cimg9.ibsrv.net/gimg/rennlis...2759ced603.jpg |
Originally Posted by Nurburger
(Post 16765685)
I have an original Wings Engineering throttle pedal that's adjustable in three planes. It's a great piece of engineering and makes heel and toeing super-easy. It slips right onto the stock pedal, so you don't have to dismantle the old pedal and fiddle with stuff like you have to do with the Rennline pedal. Setting it up just takes a few turns of a Phillips screwdriver one way or the other.
Unfortunately, the Wings is no longer available, but you might be able to find one on eBay if you set up a subscribed search. Also, there was someone on eBay selling clones of them. I have one of these clones in my parts bin and thought it looked pretty good, but the finish on it isn't as refined as the original. Here's on that sold about ten days ago: https://www.ebay.com/itm/PORSCHE-911...p2047675.l2557 Oh, and I'm moving this to the 993 forum since you have a 993. https://cimg1.ibsrv.net/gimg/rennlis...08449487b4.jpg |
On my 4S the previous owner screwed a second plastic gas pedal on top of the gas pedal to make it twice as thick so that the gas pedal is closer to brake pedal under actuation. I do find it easier to heel toe than my other one...
I like the design of the pedal mark shared above as it looks like it does something similar and has that extra nubbin sticking out the side to help. |
Originally Posted by samurai_k
(Post 16862750)
Pete |
(Post 16862750)
I like the design of the pedal mark shared above as it looks like it does something similar and has that extra nubbin sticking out the side to help. As happens with many decisions with my "Elke," I decided to just go ahead and take the high road to purchase the perforated 4 piece Rennline set. I will not install myself, but hopefully the mechanics (Rennwerke Porsche) can get the pedal placement in balance. I eschewed the rubber pip version knowing that rubber can be slippery when wet and hardens over time. |
Another great source of pedals: www.srpracing.com. They offer a choice of designs and varying styles of grip. Competitively priced, too. Note for the 993 that they offer an extension option on the gas pedal for added heel-toe compatibility.
You can make your own too.
I modified a pedal from D Zug Produkte (I think NLA) to work in a 993 and made my own brake and dead pedal. I used the adjustable floorboard stop from an early 911 that allows adjustment not available with the later pedal design. The brake pedal pad is from Tilton Engineering and can be moved up/down and side to side attached to a plate I made and had welded to the original pedal arm. I reinforced the factory mount for the dead pedal with a piece of aluminum L extrusion with threaded inserts and the dead pedal itself is from 1/4" aluminum and is "dead solid" underfoot. Not beautiful, but system really works to get what I wanted. My car has no carpet around the pedals with floorboards I made instead. The abrasive material on the brake pedal is as supplied by Tilton made of material from 3M for stair treads which I cut for the clutch and dead pedal. https://cimg2.ibsrv.net/gimg/rennlis...2c583fe3bd.jpg https://cimg3.ibsrv.net/gimg/rennlis...8d2a137104.jpg https://cimg4.ibsrv.net/gimg/rennlis...852424ec83.jpg |
Originally Posted by Mark in Baltimore
(Post 16860118)
Unfortunately, the Wings is no longer available, but you might be able to find one on eBay if you set up a subscribed search. Also, there was someone on eBay selling clones of them. I have one of these clones in my parts bin and thought it looked pretty good, but the finish on it isn't as refined as the original. Here's on that sold about ten days ago: https://www.ebay.com/itm/PORSCHE-911...p2047675.l2557 Oh, and I'm moving this to the 993 forum since you have a 993. https://cimg1.ibsrv.net/gimg/rennlis...08449487b4.jpg https://forums.pelicanparts.com/uplo...1598379745.JPG https://forums.pelicanparts.com/uplo...1598379745.JPG https://forums.pelicanparts.com/uplo...1598379745.JPG |
Forgot to share... I found the person who got the production rights to reproduce the wings pedal when I looked into the mod earlier this year.
Name is Nick. Has an insta account here with some pics of the reproduction. https://instagram.com/wingsaircooled...d=1nzqr1skm9jf |
(Post 16866657)
