993 TT starting issue.
Good afternoon gents hope everyone is well in these strange times.
Got an issue with the Turbo in that the battery went low during lockdown and since charging it it will not start.
Purchased a new OPC DME still no joy. So working backwards I have run a lead from battery to fuel pump positive and the car starts just fine. I have no power to the fuel pump fuse. The original clifford alarm has gone but there is a plug in type immobiliser on the dash but I think this is disabled when the Clifford was originally fitted.
Where does the power come from the supply the fuel pump relay? would really appreciate some advice as to what to check or test next.
many thanks
Paul
many thanks
Paul
Did you also post this on the 993 Turbo forum?
