Koni Sport or Special Active became a tough choice
#31
The shorter front bump stops are 993.343.301.00
#32
it has to be said that replacing tired 20yr old Monroe’s with a modern coil over will be a ground shifting experience. If anyone out there is still running original shocks I urge you to replace them. Even if the car only has 30k on it the difference will be mind boggling.
the difference between the current offerings is only really apparent at the limit on a track.
When it comes to active dampers, I’d like to know what the algorithm is to control the dampening resistance. On a track I can see how you could program the dampers for each corner to give the response you want. But out in the boonies, you don’t know what the next turn will be like. For that scenario, I like the car to behave consistently so that I can read the topography, apply throttle accordingly and get a reasonably predictable outcome.
sorry to ramble on. I guess my question to you is what benefits have you learned about that make you want to fork out extra $$$ for adaptive shocks?
#34
I have the front p/n handy, will look into the rear. (I forgot if the rear has the same p/n for US and M033/M030. Rear p/n I have is 993-333-105-00)
#35
I found the receipt and right or wrong, I did buy/install the numbers I gave above. All good so far!
#36
#37
@Bigwood , @Pdaddy, @993pbug , @waizone and others --- I am considering replacing my RoW M030 + Bilstein HD setup with a RoW M030 + Koni Special Active (FSD) setup .... in the name of ride compliance.
However, I have read through this thread and am somewhat concerned that that the front end with Koni Special Actives may be a bit higher than I'd like .... even if the front strut were adjusted for the lowest ride height.
I have read above that with Koni Special Actives, that the gap between the tire and the front fender is "two fingers" .... (unclear on where the struts are set wrt ride height). Can anyone provide feedback on whether I can achieve these results below (see pictures) with RoW M030 and Koni Special Actives? (below photos are what I have achieved with the Bilstein HDs). Thank you.
