CEL after Gas Fill Up
All,
See attached. Car threw a CEL (never happened before) about five miles after a fill up. My hope is that it was the gas cap but not sure given the code (P0130). I took screen shot and cleared it. (Also removed/replaced gas cap.)
Opinions/knowledge welcome.
As always, thanks in advance.
Tim in Nashville
Tim in Nashville
Hi Tim,
Unrelated to fuel fill.
P0130 = HO2S Sensor behind TWC (catalytic converter) cylinders (1-3) (left side of car) Signal implausible / Implausible Component Section / Malfunction.
Andy
- I would unplug the sensor's electrical plug on the left wall in the FRUNK and clean its plug. Plug it back in, clear the CEL (Check Engine Light) and see if it returns.
- If it returns, replace the after CAT oxygen sensor on the driver's side of the car.
- If the sensor is the original one I would just replace it. It cost $60 to $80 if purchased from an online discounter such as eBay or Rock Auto and is an easy DIY to replace. The Bosch branded ones are the same as the original ones installed in your car or purchased at the dealer in a Porsche box.
https://www.rockauto.com/en/catalog/...2)+sensor,5132
Andy
^^^Thanks Andy.
How urgent a fix is this? I'm guessing it is probably messing with mixture assuming it comes back. I'm about 1K before my next oil change and I'd just as soon have it done then.
Andy
tstafford (04-21-2020)
