993 Forum 1995-1998
Two holes in the frunk
Old Mar 20, 2020 | 05:24 PM
Anakin Skywalker's Avatar
Anakin Skywalker
Default Two holes in the frunk
There are two holes in the bottom of the frunk of my 1996 C4 cab. They go right through the floor diagonal to the emergency tire. I’m not the first owner but the car is OEM down to the last washer. The holes look like a factory feature but I can’t see any reason for them. Any R-listers who can help with this? Are they indeed a factory feature?
Old Mar 20, 2020 | 05:30 PM
pp000830's Avatar
pp000830
They are drain holes, originally they had rubber inserts pushed into them but the inserts stick out under the car and are easily knocked out by road debris. I just taped them shut on my car with a little metal duct tape. If you put the original part in them you will probably lose them again. A better solution would be a rubber plug but to be truthful I rarely look under the spare tire so, for me, the tape is good to go and has been for years.
Here is the part.
Andy
Old Mar 20, 2020 | 05:46 PM
paulkromz's Avatar
paulkromz
Old Mar 20, 2020 | 05:49 PM
P-daddy's Avatar
P-daddy
Here is the part.
Andy
Andy- you go off-road with your 993? I have not lost one in the last 10 years.
Old Mar 20, 2020 | 05:58 PM
paulkromz's Avatar
paulkromz
Nam, mine POS did not come with these shiats either doe...........
Old Mar 20, 2020 | 06:39 PM
P-daddy's Avatar
P-daddy
That's cuz your elfer is race-car!
Old Mar 20, 2020 | 07:41 PM
pp000830's Avatar
pp000830
No, but maybe some sleeping policemen stole them.
Old Mar 20, 2020 | 08:36 PM
mhm993's Avatar
mhm993
Aluminum tape.over those frunk holes in my (track) 993.
Old Mar 20, 2020 | 10:07 PM
P-daddy's Avatar
P-daddy
Interesting...
Old Mar 21, 2020 | 12:36 AM
samurai_k's Avatar
samurai_k
duct tape works great too... both of mine have it and works great to keep the moisture out
Old Mar 21, 2020 | 01:43 AM
ezinternet's Avatar
ezinternet
My sense of the drain plug's design intent is that they let moisture out from the frunk under the spare wheel.
Perhaps Porsche knew that there were ways that water (or brake fluid, or beer or wine) could pool down there, and they didn't want it sloshing around?
Porsche part #: 911-631-259-02
Old Mar 21, 2020 | 12:16 PM
SwayBar's Avatar
SwayBar
Had no idea - next time out in the garage I'll check mine.
Old Mar 21, 2020 | 01:20 PM
abiazis's Avatar
abiazis
I had duct tape over them for years, maybe close to 20, but broke down and bought 2 of the plugs at the dealer for less than $10.00 I believe......
Looks better all around, and most importantly works better if you do get water in there.........you just press them in the hole
Old Mar 21, 2020 | 02:59 PM
IHTFP's Avatar
IHTFP
Or more importantly gas. If the tank were to rupture for some reason, I think you want that gas draining out of the frunk.
Old Mar 22, 2020 | 01:25 PM
bobboinski's Avatar
bobboinski
Before I bought a gel battery I ran my battery vent out one of these holes. Never liked the original vent location.
