Clutch Pedal "pop"
Clutch Pedal "pop"
When I depress my clutch to change gears there is a distinctive "popping" feel in the pedal (not a popping sound) after the first third of the travel down.
This sensation is also present at the same point on the travel when the clutch is released. This is definitely a new phenomenon with the clutch.
Is this just a matter of a simple in cockpit pedal readjustment to fix the problem, or is there a larger internal clutch issue going on?
Thanks in advance for any help.
