993 Forum 1995-1998
turn signal problem
Old Nov 30, 2019 | 09:07 PM
russmargo's Avatar
russmargo
Default turn signal problem
noticed my driver side turn signal (front left) not working and same side rear blinking double time on my 1996 993. checked the fuse and is okay but the bulb was bad so i replaced with a new one but no change.
what do i need to check on next?
Old Dec 1, 2019 | 01:37 AM
samurai_k's Avatar
samurai_k
I had something similar happen to me when I changed to LEDs and figured out that sometimes when you remove and replace with new you may not get a solid contact inside the bulb holder. Have you tried to remove the new bulb, clean the contacts inside the holder if there is any corrosion, and pull the contact tabs a bit so it presses more against the bulb? Also try flipping the bulbs from left to right to make sure you don't have "new" dead bulb.
Old Dec 1, 2019 | 09:00 AM
pp000830's Avatar
pp000830
Have you unplugged any of the bulb harness pigtails recently? They can be accidentally switched in the rear corners causing the bulbs to blink in double-time. Since mixing up the pigtails causes this the underlying issue is attaching the wrong bulb with a different than specified wattage so if your harness plugs are not switched check that you have installed the correct bulbs by bulb number.
Andy
Old Dec 1, 2019 | 09:04 AM
Gbos1's Avatar
Gbos1
Better check the wiring as a mouse could have chewed the wire.
Old Dec 1, 2019 | 09:30 AM
pp000830's Avatar
pp000830
Yes, I had a mouse living in the bucket the AC evaporator is in, in my 1986 Carrera. Lived well with all sorts of junk food packaging in there and a ready supply of water from the coil condensation. Unfortunately, he didn't do so well in the sub-Zero winters of Cleveland where I found him desiccated sleeping in his hiding place.
Old Dec 1, 2019 | 12:03 PM
russmargo's Avatar
russmargo
thanks, i'm the mouse. put the fuse back in the wrong spot.
thanks for the help
